1. What Is Your Country Of Origin? EU - Austria
2. What do you plan to do with this monitor? Digital artwork, movies and gaming (WoW, EQ Landmark etc) Very little FPS games.
3. What resolution and screen size do you want? Minimum 1920x1080, higher would be fine also. 24" or 27" screen would be perfect. Must be an IPS monitor.
4. What refresh rate do you want? Minimum 60hz,
5. How much are you looking to spend? anywhere between $300 and $600 (not including shipping)
6. Brands Preferred (ex. Samsung, Acer, Asus, AOC, HP, Viewsonic, etc. ) no preference
7. Brands Not Preferred (state reason why)
8. Are You Buying More Than One Monitor? no
9. How Many Displays Can Your GPU Support Maximum? And what GPU and driver version are you using if applicable? MSI GTX N770 2Gb TF
10. What Port Do You Want To Connect To (ex. DVI-D, HDMI, etc). Does not matter really.
11. Is This Monitor A Primary Display Or A Secondary Display? primary
I have been looking around at a few IPS screens and this is definitely the direction I want to go in, but I have no idea which one to go for. Most of the reviews I found were at least a few years old with little information for monitors that are new or what is coming in 2014. Hopefully you fine people can help.
Thank you!
Thank you!
