I recently had the opportunity to really note how loud my RC-690 is, even though all fans are running a low speed. I'm going to rebuild, and QUIET is my primary criterion. The mobo is ATX, and there will be at most 2 (more likely 1) rotating hard drives plus a SSD. I've spent some time on SPCR, but their case recommendations appear to be dated.
My wife's Sonata III is very quiet, so I was thinking of the current version, the Sonata Elite: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129057
I would possibly replace the rear fan, or at the least remount it on rubber mounts. The CPU cooler will have a low-speed 120mm fan on it.
PSU is a SG-650, which is essentially inaudible.
I'm a little concerned about cooling, as I am considering getting a passively-cooled GPU as well; I think the most demanding game I have now is Dragon Age: Origins, which doesn't seem to need a monster GPU even for 1920x1080. Also, since getting a SSD, my system has been snappy enough that I may even go back to stock speed on my CPU if it means less noise in my living room.
A full tower is too big. I don't want a side window or other bling. Plain and unobtrusive are Good Things; this rules out the HAF 922, which appears to have too many fans anyway.
So, is that Sonata Elite a reasonable case, or do you have other recommendations up to $100-$110 (sorry, that nice-looking Silverstone FT-02 is out of my range)? Thanks.
