Looking for a quiet power supply
sanderzz
189
I think that my PSU (Corsair 430m) is on the way out as it is making very loud audible squeaking/beeping sounds. It has always been a very loud power supply as the fan spins at full rpm all the time. I was wondering if you could recommend a power supply that does not spin up unless on high load. (my system is about 300 watts maxed out)
Thanks
Antec TruePower Classic 550W is in your budget (~55 quids) while being the quietest for the price, there are quieter PSUs, fanless ones (SeaSonic X series) and some not-so cheap but still very quiet like SeaSonic G or Corsair HX, but they're out of your budget.
I have an amd fx 6300, an EVGA gtx 750 ti ACX, 8gb ram, 1tb hdd, 128gb ssd, an asus m5a78l/m-usb3 and 3 120mm case fans.
My budget is around £50-60 gbp
