I bought a PWM fan controller:
http://www.amazon.co.uk/Phobya-8x-4-Pin-Splitter-PWM/dp/B00OD7MO6E/ref=sr_1_1?ie=UTF8&qid=1453908483&sr=8-1&keywords=phobya
Long story short, I ended up with three of them but only one of the cables. The cable has a 2pin molex power and 2pin PWM control header on one end:
And on the other end there is a 4pin PWM, two of the pins go to the 2pin molex for power, and the other two go to the 2pin PWM header for fan control. This is the end of the cable that plugs into a 4pin header on the fan controller.
I am simply looking for one of these cables as the other two fan controllers that I have are useless without the cables, I can't seem to find them anywhere so any help would be appreciated!
