The 200mm would spin the slowest, allowing for the quietest option for a front intake.
Personally, I would opt for the dual 140mm intake, as the 3x120mm is more for radiator support.
do you know how the air flow in this case is i was topld my h440 was the best case in 2014... but its air flow sucks it bringed up my cpu temps over 8 c
The H440 is a solid case, however the Enthoo is on a different level. Due to its large configurable fan layout, you will be fine with airflow. (Front, bottom, top, and rear.)
how is that corsair cube case on air flow it looks like it will be good the luxe looks nice but it seems like that 200m wont keep u oto par withm y current 3 fans i have has intakes and idk how many fans i can fit in th e bottle with all my extra cabeing
If you dont want to use the 200mm you can move it to the top exhaust and run triple 120mm intake. It will just be louder.
The Luxe is easily an upgrade over the 440, simply due to its size and quality.
but how are the temps vs the h440 and i am useing an aio id liek to push/pull its 2 140mm fans on the rad
The temperatures are really hard to say, as everyones situation will be different. Specs, ambient temps, locations and so on.
If you take the time to plan out your fan installation it should be better.
right now i have my panels off on my h 440 and i am geting good temps but its loud and looks ugly =/
