Hello,
I have a Silverstone Tek ML07B chassis for my custom PC build.
I'm having a minor heating problem with my Graphics card (which is a MSI TwinFrozr GTX 770). If you look at the images of the ML07B case there is 3 case fan intakes on it.
It can be seen in the images here ML07B
There is 2 fan intakes on the bottom directly below the graphics card. It is a little off center of the edge of the card though it extends a little further past it.
The other and final intake is directly above the CPU cooler fan.
All of these have exactly enough room to handle a standard 120mm x 25mm case fan. I think will like to go with all Arctic F12 fans, which are indeed 120x25. But if need be I could go with the smaller 12-15mm thin silverstone fans which seem to have the same specs and performance.
My question is, since this is a bit of a strange setup for the fans. I am wondering how I should set my fans on this case. Should I do all three? Should not even add fans since they are so close to fans already on the coolers of the CPU and graphics card? If I add the fans should I face them all inwards towards the other fans? Currently that's what I am thinking, but it would be nice to have an exhaust fan. But the case has exhaust vents all along the top and bottom on 3 of the sides.
Any way you guys could share your opinions? I'd appreciate it.
