looking for advice on pc builds for vfx animation cg modelling rendering concept art etc.
nishicant
Commendable
Aug 18, 2018
i am a student but i want to work in the industry and freelance part time after completing my course. i expect my system to at least work another 5-10 years without any more hardware upgrade.
PC specs:
CPU: amd ryzen 2700x (8 cores)
Motherboard: asus prime x470 pro
Ram: corsair 32gb ddr4 (16x2)
SSD/HDD: samsung 500gb ssd + wd 2tb hdd
GPU: zotac blower gtx 1080ti (8 gb)
PSU: Antec EAG 750w Smps
Chassis:Corsair Spec Alpha
OS: windows 10 pro
list all the app's/softwares to be used (most of them):
blender
zbrush
maya
after effects
photoshop
corel draw
premiere pro
nuke
cinema 4d
budget: 2000-3000 usd
my questions:
1. do i need to change any components above regarding higher performance or cost effectiveness?
2. what specifications of ups (VA etc.) do i need for above PC build ?
specs look good to me, for Q1: they look ok, i would take 2 ssds (one for os other for workloads) and a harddrive for storage, and would recommend to wait for new GPUs coming out soon. q2: for a UPS its always good to have it,and for your setup about 700VA is ok. best bet https://www.apc.com/shop/uk/en/products/APC-Back-UPS-700VA-230V-AVR-IEC-Sockets/P-BX700UI but if you got power fluctuations a smart ups is better but way more expensive.
