Looking for Best 140mm White LED Case Fan
Okay, cool. I was leaning Corsair, especially with their 5 star rating on Amazon, better LEDs. Thanks Blackbird!
Oh, and this question may sound stupid, but in my case, NZXT H440, I'm going to mount two of these on top. Would I screw the fans in from beneath or would I remove the top bezel (if that's what the top of the case is called) and screw down from above?
Also, if you look at the image:
The screw holes are long ovals... Does this mean anything in particular? I've just never seen them not being small circles.
I owned 6 of the enermax in the past and they outperformed and outlasted anything else i had before switching to Noctua. They are good fans.
That's what I was planning, a nice glow in the dark. I just wish my GPU sagged a bit less. The angle of the image makes it look worse than it seems. But oh well, I'll be getting a Pascal/Polaris anyway. Cable management gets difficult with a lot of drives, but it was far worse before.
