Hey all,
My system got killed by lightning and I'm rebuilding it as close as possible to keep my Win7 install as I'm not planning to go with any newer versions of windows. I'm jumping off, for the most part. Will probably dual boot with some linux flavor and just use old windows for stuff that I'm already used to using.
I now have an MSI 970A-G46 motherboard (X16 2.0 PCIe slot) with 32 GB of Gskill Sniper RAM, and an AMD Phenom II X6 1100T CPU.
My video card got killed - it was an XFX Radeon HD 6970.
Until the lightning strike I had zero problems with this video card.
I'm not a gamer on the cutting edge, but I like my older stuff to look good. Getting an exact replacement is spotty, as they're running for around $150 on fleabay, and those are pretty heavily used.
What is a good newer card that I can get for around $200 ?
I've looked at the Radeon RX580, etc. and they seem to be a good choice. The MSI version has a lot of pretty bad ratings online - usually stating it died pretty quickly, had glitches, was impossible to get drivers for, etc.
Any input from the community would be great. I've been out of the loop for a few years, so I'm not up on the latest and greatest.
