Looking for case in $100-$150 range with great airflow
Tim92G
13
I recently bought the Fractal Define R4 but I am not happy with the amount of airflow it has.The heat from my GPU is not being moved out through the exhaust, and coming out the side air vents near where I sit, making it very hot. The other cases I looked at were the Phanteks Enthoo Pro and Corsair 650D. Any recommendations?
I would suggest Phanteks Enthoo Pro. Excellent Case.
But you can
* Install 2 Front 140mm Intake fans [1 is included]
* Remove that 120mm Side Exhaust fan & place it in bottom
* Install 2 Top 140mm Exhaust fans
Then your Air pressure will be Equivalent [2x140mm+1x120mm Intake = 2x140mm+1x120mm Exhaust]
But you can
