Question Looking for cheapest way to utilize an EVGA 1080 Ti ?
Aug 7, 2023
I’m trying to play Baldurs Gate 3 as cheaply as possible. I already have an EVGA 1080 Ti card. What is the cheapest used pc that would run this GPU and Baldurs Gate? I’ve looked at the "build your own pc" on eBay, omitted the graphics card, and it comes to about 140$ that I think would work. I’ve also seen used computers with i5 CPU’s for 80$ that I don’t think would work. Thoughts? Thanks
Link to exact graphics card
You might want to include links to those listings.
Mentioning where you're located would also help.
Thanks, I’m in Connecticut.
HP Desktop PC Computer Tower Elite 8100, Intel Core i5-660 up to 3.6GHz, 4G DDR3, 500G, DVD, WiFi, BT, VGA, DP, Windows 10 Pro 64 Bit-Multi-Language Supports English/Spanish/French(Renewed) https://a.co/d/e4i9wJ3
I’m not sure if the card fits or if there is enough power. Also it has an i5 but is that version good enough to run Baldurs Gate/the graphics card.
Same questions for this one:
Thanks again.
