Looking for confirmation on compatibility of parts.
bchill
7
I'm building my first computer and I was wondering if these parts would all be compatible together. I don't think there's any problem other than the space regarding the graphics cards. Here's the parts I've chosen.
Case:
LIAN LI PC-B25B Black Aluminum ATX Mid Tower Computer Case - Retail
Item #: N82E16811112148 - http://www.newegg.com/Product/Product.aspx?Item=N82E16811112148
CD/DVD Driver:
ASUS 20X DVD±R DVD Burner with LightScribe Black SATA Model DRW-2014L1T - Retail
Item #: N82E16827135156 - http://www.newegg.com/Product/Product.aspx?Item=N82E16827135156
Hard Drive:
Western Digital VelociRaptor WD3000GLFS 300GB 10000 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822136260 - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136260
Graphics Card(s):
2 x EVGA 512-P3-N874-AR GeForce 9800 GTX+ Superclocked Edition 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
Item #: N82E16814130385 - http://www.newegg.com/Product/Product.aspx?Item=N82E16814130385
Sound Card:
Creative Sound Blaster X-Fi XtremeGamer 7.1 Channels PCI Interface Sound Card - Retail
Item #: N82E16829102006 - http://www.newegg.com/Product/Product.aspx?Item=N82E16829102006
Power Supply:
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
Item #: N82E16817139006 - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
Memory:
OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model OCZ2RPR10664GK - Retail
Item #: N82E16820227289 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820227289
Motherboard:
EVGA 123-YW-E175-A1 LGA 775 NVIDIA nForce 750i FTW SLI ATX Intel Motherboard - Retail
Item #: N82E16813188026 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813188026
Processor:
Intel Core 2 Duo E8600 Wolfdale 3.33GHz LGA 775 65W Dual-Core Processor Model BX80570E8600 - Retail
Item #: N82E16819115054 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115054
My main concern was whether or not I could fit two 9800 GTX+'s on the 750i without having to sacrifice anything. And then I was wondering if that would fit in the case I've chosen. I've searched quite a bit for an answer to this question, but I haven't had much luck. If you've read this far into my post, I appreciate your time.
Thanks, Bc.
The motherboard is an NVIDIA SLi board, so it is specifically designed to handle to NVIDIA GPUs like the 9800 GTX+s you selected. I'm betting the case will be a tight fit with two full-length GPUs like the 9800 GTX+s with the HDD bay placed where it is. You might want a slightly bigger case like the Antec Nine Hundred to fit two full-length cards. I have the Nine Hundred and it will fit very long GPUs easily, whereas my Cooler Master case that's roughly the size of the Lian Li you put there is pretty tight with a full-length GPU.
The rest looks really nice. It ought to be a really nice setup. Just don't forget to add an OS to that list and you'll be good go go.
bchill
7
Yeah.. Windows Vista Ultimate SP1 32-bit comes in a bundle with one of the products, so I think I'm going to go with that. Thanks for such a quick response. Very helpful. How tight of a fit would it be and would it be that bad for the computer? I spent a lot of time trying to decide on a case and I feel like now that I've finally chosen one, It'd be hard to find another that suits me as well. :/
Edit:
Assuming this is the case you're referring to:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021&Tpk=Antec%20Nine%20Hundred
I was comparing the sizes of it to the one I previously listed and here's what I get:
Antec Nine Hundred:
Width: 8.1"
Height: 18.4"
Depth: 19.4"
Lian-Li B25B
Width: 8.27"
Height: 17.72"
Depth: 20.28"
Assuming it's the height that you were saying may cause it to be a tight fit, would 17.72" vs. 18.4" make that much of a difference? Thanks again for your help.
sighQ2
541
With only 2 drives (hdd, dvd) and only a PCI soundcard to consider re fit cables on the mobo itself, you are looking at winding a cable to connect point A to B for the hdd, and the pci-Sound is going to probably be well away from the vidcards.
The only problem I can see is air flow between the sound and vidcards, and I doubt soundcard is an issue. Assuming the board is MADE FOR SLI, you will likely be good to go.
I thought the case measurements were a good consideration; but it seems your case is very close to the other recommended case, in fact wider, so even more clearance re dvdrw approaching mobo, and routing cables = n/p
Be sure to air flow.
Do it. :)
bchill
7
This is exactly what I was hoping to hear, and yeah.. the board is made for SLI. Thanks a lot for the quick responses. This seems to be one of the nicer forums I've been to, so you'll probably be seeing me around more often. I'll post pictures of the spacing between the HDD and Graphics Cards when I build it for anyone who may be interested in doing a similar setup.
Thanks again, Bc.
