Question looking for cooling for Asus z690 Hero that will be OK with memorys
I7210I
84
Hello,
I have tried on my Asus z690 HERO and the kingstone fury, the Noctua d-15 and it looks like that it's too much sloe to the memory and the heat sinks over there, Plus if I install the second ventilator, it touches the memorys,
here's some pics:
https://ibb.co/0ssp57c
https://ibb.co/vY4vZ7d
https://ibb.co/4tbYkPh
https://ibb.co/MgvY13H
https://ibb.co/qNPx3ZL
https://ibb.co/FJw8FWx
https://ibb.co/QdfjcnR
https://ibb.co/QH3qQFp
https://ibb.co/Jpht1m1
https://ibb.co/7jQ6mHx
what I can do to cool up the system?
I7-12700K
Asus Z690 Hero
2*16 kingstone fury
Thanks
Lutfij
Even if the fans touch the top of the ram sticks, you're not going to have any issues. The benefit of using clips to mount fans to the heatsink allows the end user to adjust the height of the fan on the heatsink. If your case allows with more clearance, then move the fan a couple of notches above where they are now. Like I said prior, even if the fan's outer shroud touches the top of the sticks of ram, you won't encounter any issues.
Make and model of your case?
If I was building around that motherboard, I'd have looked into an AIO, to avoid the tall VRM heatsinks.
I7210I
84
Thanks,
My case is that CM STORM2 but I think to change it to get the usb type C at the front for example, but I don't have suggestion right now,
Also it's not better to take small cooler right now?
