Looking For Custom Water Cooling Help/Advice
ThisChunkyMonkey
59
Hello everyone! I'm Currently looking into a custom water cooling loop for my new PC build. I want to water cool my CPU. I've spent a lot of time looking into water cooling for my 1st build but just never went through with it but now I really want to invest in a high quality water cooling system. I've never dealt with custom water cooling as I mentioned but I do have a closed water cooling kit (Corsair H110). I am confident in the whole concept of water cooling but when it comes the choosing high quality parts is where I really feel overwhelmed. Basically, I need someone who can recommend the necessary parts for a water cooling loop for my build. If there is anyone who can help a newbie out in this situation it would really help! :)
I'll list my PC build here: http://pcpartpicker.com/p/D7s6kL
This build is for overclocking and gaming.
Your first step would be to go through the watercooling sticky. Please be patient with the sticky though as there is alot covered in it after a few read through's the information will click in place. At the end of the sticky you'll find links to retailers that cater to watercooling components and even stocking their kits. It might not sound like much but when setting up a custom level watercooling loop it's best to figure out what you in terms of performance and later pass on an inquiry to a list of parts you've chosen for us to take a look at in case one or two details need fine tuning.
Watercooling can be tagged to be like Lego, it's fun building things following instructions but once things are done and dusted and at most times is over done it's not fun anymore so for the best part you should read up on the sort of performance you want to hit, the budget you want to allocate and the sort of parts your're looking to pick. Remember this is a canvas and taking our suggestions for a loop will only be our way of doing things, not yours.
* the watercoolign sticky is linked in my sig.
