ok first off, i am really sorry if this is posted in the wrong section im quite new to this website, i didnt see a thread about fans.
anyways, so im building a pc and i have chosen this case https://www.newegg.com/Product/Product.aspx?Item=N82E16811112584&ignorebbr=1&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Cases+%28Computer+Cases+-+ATX+Form%29-_-N82E16811112584&gclid=CjwKCAiAmO3gBRBBEiwA8d0Q4lAka4_3eR5BH6852j_XthVSxoeJ3-cuSudO5NReNM8lMnkDo19-xRoCXwMQAvD_BwE&gclsrc=aw.ds (sorry for long link) and ive decided to use the front 120mm fan placements for a 360mm radiator. and the top and bottom 120mm fan placements will use these fans https://www.newegg.com/Product/Product.aspx?Item=N82E16835213005&Description=delta%20120mm&cm_re=delta_120mm-_-35-213-005-_-Product and i looked at power requirments for these fans and each one will take 5.5 watts minimum but most case fans typically use 1.8 watts. so to my knowledge these fans will use a lot of power. and ive read some where that useing to much power from your motherboards fan headers can cause your motherboard to break. so i know i will need a fan hub for this. but could some one reccomend me one that can supply these fans with a good amount of watts? im looking for 8 pin headers on this hub as i might try putting in 2 80mm fans in the back.
thanks for any reccomendations!
