Is that an 80mm fan?
If so, any 3-wire 80mm fan will work just fine, as long as you find one with the same rotational speed, and the dame general voltage and current requirements.
It's safe to assume black to be the negative lead, the red to be the positive lead, and the yellow to be the fan speed (tachometer) output to the motherboard. The only question is whether the positive supply is 12VDC or 5VDC, although 12VDC would be the expected value.
If 80mm and 12VDC, this fan would work well:
https://www.amazon.com/product/dp/B002R9RBO0
