Looking for help with first build
OptOut
5
Approximate Purchase Date: August 18th
Budget Range: up to $1500 or 1100 Euros After Rebates; After Shipping
System Usage from Most to Least Important: Gaming, Coding, Web Surfing and watching Videos
Are you buying a monitor: No
Parts to Upgrade: Everything
Do you need to buy OS: No
Preferred Website(s) for Parts: amazon.de (I think it ships to Holland)
Parts Preferences: Intel CPU and NVIDIA Graphics
Overclocking: Yes
SLI or Crossfire: Maybe, if i can afford but i won't sweat it if it doesnt fit in the budget
Your Monitor Resolution: 1920x1080
Additional Comments: It needs to look good with a color scheme (for the build i put together i chose black and red)
I am open to watercooling.
If you think i will get way more performance by increasing the budget by $200 then go ahead but i would prefer to stay under $1500
Games i would like to play on the highest settings:
1) Planetside 2
2) Borderlands 2
3) Bioshock
4) Tomb Raider
5) Minecraft
6) Also Blender (the software)
And Most Importantly, Why Are You Upgrading: Trouble running games and graphics card started overheating and crashing
Build: http://de.pcpartpicker.com/p/1huIa (I can't get it to fit the budget)
Total: €1452.88
CPU Intel Core i7-3770K 3.5GHz Quad-Core €299.00
CPU Cooler Corsair H100i 77.0 CFM Liquid €99.90
Motherboard Asus Maximus V Formula EATX LGA1155 €267.39
Memory G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 €64.98
Storage Samsung 840 Pro Series 256GB 2.5" SSD €200.92
Video Card EVGA GeForce GTX 660 Ti 2GB €230.89
Case Cooler Master HAF 932 Advanced ATX Full Tower €109.90
Power Supply SeaSonic 850W ATX12V / EPS12V €179.90
