Looking for help with my Computer
Kgomotso
Hi Miss fix it, I need your help with my PC. I don't know what's the problem. When I On it.. It says
Press F8 for BBS POPUP
Checking NVRAM..Update OK!
Initializing USB Controllers.. Done.
128MB OK (DDR:200MHz) (32MB Shared Memory Size Used)
CMOS Settings Wrong
CMOS Date/Time Not set
Press F1 to Run SETUP
Preaa F2 to load default values and continue
Then I Press F1 for SETUP, to set the date nd time and load default setting..
After that it says
VIA Technologies, Inc.VIA VT8237 Serial ATA RAID BIOS Setting Utility V2.20 Copyright (C) VIA Technologies, Inc. All Right Reserved.
Scan Devices, Please wait...
Press <Tab> Key into User Windows!
Serial_Ch0 Master: No Device
Serial_Ch1 Master: No Device
Then show a blank black screen for few seconds..
Then says..
Novell NetWare Ready Firmware V1.00 (940810) (C) copyright 1991 - 1994 Novell, Inc. All Right Reserved.
Press <Shift-Tab> key to display select Menu.
Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key_
When I press "Shift-Tab" nothing happens even when I press any key.. It stuck here with this message..
Please help..
