I’ve been having trouble with the rgb lights on my case fans as well as the built in lights on my case. Hoping someone can help.
Background: Built the PC in 2019, I don’t think the whole setup is needed here, but the relevant stuff is it has a gigabyte Z390 Aorus master motherboard, Phanteks Evolve X case, and Phanteks Halos RGB fan frames on the 3 case fans as well as the 3 radiator fans attached to my Corsair H150i CPU cooler, for 6 total. 850 W power supply. RGB is also present on my video card, motherboard, RAM, cooler. All of those have worked fine. When the PC was first built ALL of the rgb worked perfectly, including the lights that aren’t working now. The only hardware change I’ve made was to the GPU, upgraded from 2070 super to 3080ti (MSI gaming X trio). The problem started after that video card change, but not right away, it was a few months later.
At some point the RGBs on the Halos fan frames (all 6) as well as the 2 RGB strips integrated into the case (and all of these are connected to the motherboard through the same connector) started acting erratically. I couldn’t control color, they were dim, they’d flicker on and off. This happened right from booting up and didn’t seem to be affected by how hard the machine was working/how much power I was using. I had wondered in the 3080ti was taking too much power and somehow that was causing the issue, but it didn’t seem to make a difference if I was doing nothing or running a stress test, lights behaved the same. I checked the connections, found no issues. Then I just lived with it for about the past year. Recently, I’ve been doing some more troubleshooting, and hopefully someone can help me along further.
I found that if I disconnect all the fan frames and just leave the case lights connected to the motherboard it helps a little. If I then turn off the front case light, and leave just the side light on, it glows the full strength and I can change the color between the red, green and blue presents in the rgb fusion app. Other colors still don’t work, and most just show as red (yellow preset showed as green, but orange, pink, purple, white etc all show as red). If I use the color wheel I can get a few other colors, but most still just show as red. If I turn the front case light back on, then I can still do these color changes, but the strength of the light is diminished. If the 6 case fan frames are connected, everything goes back to the flickering red, can’t change colors at all.
So to me, it seems like at a minimum there’s an issue with power being delivered. Fewer light connected and I get normal light intensity, more connected and I get dimmed lights. But I’m totally confused about why I can get some, but not all colors to display. I know the LEDs can produce the colors because I caught a half-second glimmer of the ”rainbow” color scheme on my case light when I turned it on from an “all off” setting, but then it reverted to just showing red.
Any guidance?
Any guidance?
