Question looking for low cost solution to my problem (old rig not compatible with win10)
anaturelover
78
hi in 2009 i build a killing machine for gaming. today i dont do gaming anymore :) .
my prob is that my mobo is not supported compatibility with win10( istill run win7) . i have asus p6t v2 deluxe . see my rig below.
now. i read some people do find work around to run win 10 with p6t deluxe v2 but i dont know what it implies . what does it imply? vulnerability?
concern1:i want not to spend to much money to have a compatible system with win 10 and possibly the next windows
concern2: iwant to be good for couple years without having to rechange my hardware because of futur non supported hardware(i had the same rig for 12 years without need for change and id like to do another 10 years with the change i will do soon?
My need in not for gaming anymore . maybe a bit of videoediting just a bit but i do have a tendency to have 3 firefox windows with 5 tab each in my everyday serches and work so i want not to wait to long for booting.
I have read that amd do less chaging in hardware than intel witch maybe can led to longer lifespan in terms of support by windows , correc me if im wrong...
what would you do?
should i try to find a mid range recent mobo combo processor and keep all my hardware ddr3 an gpu ? how long would that be supported?
should i buy an cheap yet performant" couple years old "combo that fit my hardware and see in 6 years what i want to do?
should i try to install win10 1903 for one year and see if the newer versions of win10 give me problems delaying the question to later?
here is my rig.
megahelm prolimatech cooler for socket 1336 (passive cooler with 4 noctua fans)
I have 12 gig ram 12.0GB Triple-Channel DDR3 @ 534MHz (8-7-7-20) corsaire dominator cmp12gx3m3a1600c9 999-24 1,65 ver 2,12a 12gb 3x4gb 1600mhz
gpu 896-P3-1255-AR - eVGA GTX 260 CORE 216 55NM 576MHZ 896MB 1.998GHZ GDDR3 PCI-E 2XDVI-I HDTV OUT
P6T DELUXE V2 - ASUS P6T DELUXE V2 S.1366 INT X58/ICH10R ATX 3PCIE X16,6D.DDR3-1600MHZ FSP WIFI-AP GBLAN
CP-850 - ANTEC CP-850 850W CPX FORM ATX12V V2.3 PWR SUP DUAL PCB LAYOUT
BX80601920 - INTEL CORE I7-920 2.66GHZ 8MB CACHE LGA-1366 4.8GT QPI Intel Core i7 920 @ 2.67GHz 50 °C Bloomfield 45nm Technology
HD103UJ - SAMSUNG SPINPOINT F1 HD103UJ 1TB SATA 3G 7200 RPM 32MB CACHE
Second hdd western digital 500 gb sata 32mb cache 7200rpm
tx
