Looking for monitor solution. Consoler went PC
relica8
4
Was a console gamer and just built a new PC. I was using my Samsung 22" Syncmaster for the console. Once I started using the PC on this monitor it seems like players (BF3) in the distance are much smaller now. The graphics are way better now though. My PC play ultra with over 100fps so it's good. So am I jusy needing a bigger monitor now? Did the console just display an overalll zoomed in image unlike PC? I tried a cheap 27" previously but the size was kind of overwhelming up close. Is a 24" the answer or are there other settings that I can adjust. Thanks in advance.
Thanks so much. I will check that out. The menu does give that option but I honestly can't tell the difference whether I change FOV to 60 or 90.
