Looking for Oculus compatible thunderbolt 3 or usb c hub
FawnPoem
11
Hello, I'm considering getting a dell xps 15 9575 2in1 for work purposes and VR gaming on the side. This is intended to be my secondary gaming machine but there's one problem. There are only 2 thunderbolt ports and 2 usb c ports. I've tried looking for a solution to this question but I wasn't able to do so. I'd like to find something that will support 2 rift sensors minimum and the rift HMD's hdmi and usb. Thank you in advance.
https://www.theverge.com/2018/7/17/17583362/virtuallink-vr-headsets-oculus-valve-microsoft-connect-usb-c-cable
Your current best bet is an ADAPTER if you can't wait for the upcoming VR headsets that use that single Type-C connection.
https://venturebeat.com/2019/01/05/accell-shows-off-usb-c-vr-adapter-for-oculus-rift-windows-vr/
It's $50USD:
https://www.accellww.com/products/usb-c_vr_adapter
*I am confused by the single USB3.0 connection on that adapter as it says it is RIFT compatible. Does that mean no sensors? I'll look for a manual.
UPDATE: I just realized that the adapter is for the HEADSET only which only needs that single USB3.0 connector and HDMI v1.3+... for the other USB3.0/2.0 connections you could just get a suitable, separate Type-C adapter with whatever connections you need since you'd have two.
You may be able to find an adapter with everything you need but that's all I found so far. I assume the newer USB Type-C VR headsets will just merge HDMI and the 1xUSB3.0 connector anyway so you'd still likely need a separate USB Type-C to (2xUSB3.0 + 1xUSB2.0 or just 3xUSB3.0 to cover the USB2.0 a different way??… I believe that is accurate).
I don't know if some adapters would have any LATENCY issues but you'd want to confirm that as this is pretty real-time stuff.
Yah, they do exist: https://www.startech.com/ca/Cards-Adapters/USB-3.0/Hubs/4-port-usb-3-hub~HB30C3A1CFS
