Looking for over clocking CPU problems
Is that I have overclocked my CPU amd a6 4400m to 3.2 but it does not take effect until I plugged in my charger, it does not work on battery pls what the problem , it will just get back to it's normal 2.7 processing speed but Immediately when I plug in it will catch up to 3.2 processing speed any help pls.
Seems normal to me, when on battery power laptops drop speed. You can go into the power manager and set battery side to run on full power, that may keep the speeds the same.
