Looking for potential problems with my $2k build before I purchase.
StargateSG123
Commendable
Nov 25, 2016
Hey everyone!
Just looking for any reason I shouldn't buy these parts for my Cyberpowerpc custom pc build.
I'm planning on using this pc to play games and to multitask a lot at 2560x1440, also planning to add a second monitor later on. I made sure to choose all named brand parts as I've read a lot of bad things about the part they give you otherwise. Every piece seemed to get good reviews on amazon, I'm mainly worried about how they will all work together.
Going to give my explanation for some of my choices that may be iffy.
  • I don't want to build it myself mainly because I take a lot of time to do things. I've spent easily 50 hours researching this past week about what parts I want and the pros and cons of all the things; I would see myself spending way too long to put a computer together, and I would be irrationally scared that I would break something or reduce it's maximum life expectancy.
  • Cyberpowerpc has had some real horror stories, but they all seem to be from 2014 or 2015; also a lot of them seem to be because of knockoff parts which shouldn't happen here. Building with these specs on other sites either costs 200-400$ more or it doesn't let me choose as many thing to be sure of what companies all the parts are coming from. So I'm planning on taking this chance on cyberpowerpc and hopefully it works out.
  • I wanted a better CPU cooler than the stock air one, but anything bigger than that can be heavy enough to cause problems during shipping from what I've read, I think the water cooling will ship safer. I'm not ruling out overclocking in the future, but for now I'll just have overkill fans and cooling in general the colder the better right?
  • I also know that an i7 6700k is overkill for gaming and the price would be better put into a 1080, but I feel like it would be easier for me to add another 1070 myself down the line than if I want to play a game that actually uses hyper-threading and I'm sitting there with my overclocked i5 6600k.
  • Speaking of overkill I'm putting in 32 GB of ram and I head that's more than I need, however when I bought a computer 5 years ago 8GB was higher than recommended iirc and now I can hit that easily with the right games.
So the main things I'm not sure about yet are the case itself, and how the finished product will fit and function in the case with these fans; But anything you have to say will provide more info for me to help me make my decisions.
I copied the "details" from the shopping cart on their website and removed "freebie" items or things I didn't buy that said "none".
I'm going to head to bed and I'll be making the choice on whether to tweak it more, or buy it as I have it built below tomorrow.
Ok! Thank you for reading and thank you in advance for any advice or words of wisdom!
CARE1: Ultra Enhanced Packaging Solution - Protect Your Dream System During Transit [+19]
CARE2: Cooler Master Thermal Fusion 400 Extreme Performance CPU - Thermal Compound Optimized for Thermal Dissipation [+10]
CAS: ZALMAN Z11 NEO Mid-Tower Gaming Case w/ USB 3.0 & Toolless Drive Bays & Side-Panel Window [-10]
CASUPGRADE: RGB Multi-Color 16 color LED 1x interior light strip w/ Remote Controller
CPU: Intel® Core™ Processor i7-6700K 4.00GHZ 8MB Intel Smart Cache LGA1151 (Skylake)
CS_FAN: 3X 140mm Thermaltake Riing 14 Series High Static Pressure 140mm Case/Radiator Fan [+49] (Orange Color LED)
FA_HDD: Vigor iSURF II Hard Disk Drive Cooling System [+21] (1 x System)
FAN: Corsair Hydro H90 140mm Liquid CPU Cooling System w/ Copper Cold Plate - Enhance Cooling Performance [+46] (Dual BLUE (Push-Pull) Tt Riing 14 Series Case/Radiator Fan [+29])
HDD: 500GB Samsung 850 EVO Series SATA-III 6.0Gb/s SSD - 540MB/s Read & 520MB/s Write [+127] (Single Drive)
HDD2: 2TB (2TBx1) Western Digital Caviar Black SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD [+147] (Single Drive)
IUSB: Built-in USB 2.0 Ports
MEMORY: 32GB (8GBx4) DDR4/3000MHz Dual Channel Memory [+180] (ADATA XPG Z1)
MOTHERBOARD: * MSI Z170A Gaming Pro CARBON ATX w/ Programmable Lighting, USB 3.1, 3 PCIe x16, 4 PCIe x1, 1 SATA Express, 4 SATA3, 1 Ultra M.2
MOUSE: CyberpowerPC Standard 4000 DPI with Weight System Optical Gaming Mouse
NETWORK: Onboard Gigabit LAN Network
NOISEREDUCE1: Anti-Vibration Fan Mounts [+9]
OS: Windows 10 Home (64-bit Edition) w/ $100 Windows Store Gift Card
OVERCLOCK: No Overclocking
POWERSUPPLY: * 750 Watts - Corsair CX750M CX Series Modular 80 PLUS BRONZE Certified Active PFC Power Supply [+56]
PRO_WIRING: Professional Wiring for All WIRING Inside The System Chassis - Minimize Cable Exposure, Maximize Airflow in Your System [+19]
RUSH: Standard Process Time: Ship within 7 to 12 Business Day
SERVICE: 3 Years FREE Service Plan (INCLUDES LABOR AND LIFETIME TECHNICAL SUPPORT)
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
VIDEO: ASUS Turbo GeForce® GTX 1070 Gaming 8GB GDDR5 (Pascal)[VR Ready] [+13] (Single Card)
WARRANTY: STANDARD WARRANTY: 1 Year Parts WARRANTY + ONE (1) YEAR SHIPPING [+10]
_PRICE: (+1933)
Total Price: $1,933.00 (before tax I think)
EDIT- Based on Isokolon's advice I have made these changes:
Removed the Vigor iSURF II Hard Disk Drive Cooling System
Swapped my GPU from an ASUS Turbo GeForce® GTX 1070 Gaming 8GB GDDR5 (Pascal)[VR Ready]
to an MSI GeForce® GTX 1070 Gaming X 8GB GDDR5 (Pascal) [VR Ready]
Swapped my PSU from a 750 Watts - Corsair CX750M CX Series Modular 80 PLUS BRONZE Certified Active PFC Power Supply
to a 750 Watts - Corsair RMi Series RM750i 80 PLUS GOLD Certified Fully Modular Ultra Quiet Power Supply
New total price with these changes: $2,106.00 (They have been changing the price of some pieces)
Here is a part picker link close to the cyberpowerpc build currently: https://pcpartpicker.com/list/34KrYr
If anyone has anything else to add let me know!
EDIT 2- Ok I bought the PC, now we wait and hope that nobody working on or transporting my computer is in a terrible hurry.
any of the MSI are fine, as are the EVGA Superclocked and the EVGA Hybrid.
dropping 60$ on that is the difference between a 40dBA 85°C card and a basically inaudible 60°C card.
as for the PSU: for overclocking 550W is still fine. from the units listed, there are only 2 quality units: the Corsair RMi/RMx & the Cooler Master V.
for SLI I'd pick a 750W unit, 850W if you're into heavy overclocking of the SLI'd cards, got the cash and want some comfortable headroom, but 750W should be more than fine.
Mhh I see a few improvements here
First: you've picked a blower style GPU
I only recommend this for ITX cases. As far as I remember (correct me if I'm wrong) your case can take full ATX mainboards. Therefore I'd pick an ASUS Dual or ASUS Strix 1070 (if you wanna stick with Asus)
If you can afford it a 1080 would be nice.
PSU is overkill in wattage but low grade. I would pick a better unit if possible. Like a Corsair RMx, EVGA GS or G2 or any Seasonic/XFX/Superflower unit with 550W (except the XFX XT)
Cooling for your HDDs ain't necessary
I'd like to stick to the 1070, I think that will be enough since I'm just shooting to hold 60fps.
I have listed below all of the 1070 options they give me; taking into account that I'd like to be able to SLI another one in the future, which one of those would you recommend?
GeForce® GTX 1070 8GB GDDR5 (Pascal)[VR Ready] (Single Card) [-13]
GeForce® GTX 1070 Founder's Edition 8GB GDDR5 (Pascal)[VR Ready] (Single Card) [+45]
I have this one selected currently:
EVGA GeForce® GTX 1070 Superclocked ACX 3.0 Edition 8GB GDDR5 (Pascal)[VR Ready] (Single Card) [+64]
EVGA GeForce® GTX 1070 FTW GAMING ACX 3.0 Edition 8GB GDDR5 (Pascal)[VR Ready] (Single Card) [+71]
EVGA GeForce® GTX 1070 Hybrid Gaming 8GB GDDR5 (Pascal)[VR Ready] (Single Card) [+64] [Black Friday Mega
Sales - Free upgrade from EVGA GeForce® GTX 1070 Superclocked ACX 3.0]
$20 Mail-in rebate MSI GeForce® GTX 1070 Gaming X 8GB GDDR5 (Pascal) [VR Ready] (Single Card) [+58]
MSI GeForce® GTX 1070 SEA HAWK 8GB GDDR5 (Pascal)[VR Ready] (Single Card) [+117]
Given that I want to have the options to overclock and/or SLI without changing PSUs will 750W be enough?
Here is roughly the same PC in part picker (before SLI) if that helps: https://pcpartpicker.com/list/fJFDkT
Also going to list out my 650-1000W PSU options from their website below.
650 Watts - Corsair CX650M CX Series Modular 80 PLUS BRONZE Certified Active PFC Power Supply [-20]
650 Watts - Corsair RMi Series RM650i 80 PLUS GOLD Certified Fully Modular Ultra Quiet Power Supply [+43]
$30 Mail-in rebate * 750 Watts - Thermaltake SMART Series SP-750PCBUS 80 PLUS BRONZE Certified Active PFC Power Supply [-18]
I have this one selected currently: $20 Mail-in rebate * 750 Watts - Corsair CX750M CX Series Modular 80 PLUS BRONZE Certified Active PFC Power Supply
750 Watts - Corsair RMi Series RM750i 80 PLUS GOLD Certified Fully Modular Ultra Quiet Power Supply [+54]
750 Watts - EVGA SuperNOVA 750 G1 80 PLUS Gold Power Supply [+0]
750 Watts - IN WIN Classic C750W Aluminum, 80 PLUS PLATINUM Certified Full Modular Active PFC Power Supply [+47]
800 Watts - Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready [-48][Black Friday Mega Sales - Free upgrade from Corsair CX430 V2 430 Watt]
850 Watts - EVGA 850W GQ 80 Plus Gold Power Supply [+33]
850 Watts - Corsair CSM Series CS850M 80 Plus Gold Certified Modular Ultra Quiet Power Supply [+54]
850 Watts - Corsair RMi Series RM850i 80 PLUS GOLD Certified Fully Modular Ultra Quiet Power Supply [+74]
$40 Instant Off New! 850 Watts - Cooler Master V850 - 850W 80 PLUS Gold Fully Modular Power Supply [+77][Black Friday Mega Sales - $40 Instant Off!]
900 Watts - IN WIN Classic C900W Aluminum, 80 PLUS PLATINUM Certified Full Modular Active PFC Power Supply [+73]
1,000 Watts - Standard 80 Plus Gold Power Supply [-40][Black Friday Mega Sales - Free upgrade from 500Watt EVGA]
1,000 Watts - Corsair RMx RM1000X 80 PLUS Gold certified Fully Modular Ultra Quiet Power Supply [+61]
$20 Mail-in rebate * 1,000 Watts - Corsair RMi Series RM1000i 80 PLUS GOLD Certified Fully Modular Ultra Quiet Power Supply [+84]
I'll remove the "Vigor iSURF II Hard Disk Drive Cooling System"
Thanks for helping!
Thank you for the advice, I swapped the GPU and PSU over to these!
