Looking for power supply and cooling solution
wjeffery38
I am in the process of building my own computer.
After much research, I have decided to go with the following setup: http://pcpartpicker.com/p/y92Xzy
I am looking for suggestions on the power supply. I do not want to waste money on a power supply that is far too overpowered.
Furthermore, I want suggestions on a cooling system that fits best in the tower I selected.
I was hoping to use a liquid cooling system, however I have heard concerns about cooling systems fitting in certain towers.
If further information than the attached list is necessary, please let me know.
Hi - You can run the sys with a good quality 550w unit, however since you will be overclocking,
I suggest a good quality 650w unit.
You didn't specify a budget...
You didn't specify a budget for the PSU, so I'll suggest two, one full wired and the other modular
which I recommend.
http://pcpartpicker.com/mr/newegg/xfx-power-supply-pro650wp1650snlb9
http://pcpartpicker.com/mr/ncixus/evga-power-supply-220gs0650v1
http://pcpartpicker.com/mr/ncixus/evga-power-supply-120g10650xr
The Storm Stryker tower will house liquid cooling systems, but it is also spacious, has 4 internal
fans included, and if you go with a modular power supply(better air flow), I believe a good
air coolor will be more than sufficient. I suggest the 140mm fan variety from Noctua,
Phanteks, or Cryorig.
BTW, nice build!
http://pcpartpicker.com/mr/newegg/phanteks-cpu-cooler-phtc14pebk
http://pcpartpicker.com/mr/newegg/noctua-cpu-cooler-nhd14
