I'm gonna do the Firegl - 128t flash w/ my Radeon 9800 PRO, and if it doesn't work I'm going to simply overclock it. Either way, I'm not concerned about that, I just want a cheap, quiet, cooling for my card. Any recommendations? I won't take it any higher than stock 9800 XT speeds, so really any cooling as good or better than a 9800 XT should do the job. I want it as quiet as possible though, any recommendations? Also, how do you guys get the heat sinks to stay on there, adhesive? Does that usually come with the gpu cooler?
