I recommend Water Cooling....
Ohh for air...
Who needs silent when your air cooling? It should sound like a TURBINE is reving up next to your PC!
TURBINES TURN ON THE WOMEN!
Ok, time for work...
http://www.frozencpu.com/cat/l3/g40/c14/s220/list/p1/Air_Cooling-CPU_HeatsinksCoolers-AM2-Page1.html
Thats almost every option you got...
So lets list them...
Zalman CNPS9500 AM2 Ultra Quiet CPU Cooler
Thermaltake Mini Typhoon Value Back Universal CPU Cooler w/ Dual 50mm LED Side Fans
Thermaltake Big Typhoon VX 5 in 1 CPU Cooler w/ Heatpipe Cooling Technology
Thermalright SI-97A Aluminum Heatpipe CPU Cooler (AMD)
Thermalright HR-01
Thermalright Ultra-90
and
Koolance CPU-300 and CPU-305
Now the universals
http://www.frozencpu.com/cat/l3/g40/c14/s45/list/p1/Air_Cooling-CPU_HeatsinksCoolers-Universal_Socket-Page1.html
AeroCool Dominator Triple Heatpipe Heatsink w/ 140mm Fan (Pentium 4 S775 & S478/ AMD 64 & XP 3600+)
AeroCool High Tower HT-101 JR Heatsink (Pentium 4 / Athlon XP / AMD 64)
Cooler Master Hyper 48 (KHC-L91-U1) CPU Cooler - Pentium 4 and AMD K8
Cooler Master Hyper 6+ CPU Cooler - Universal Mounting (RR-UNH-P0U1)
Scythe "Katana CU" Dual Heat Pipe All Copper CPU Cooler (SCKTN-CU1000)
Scythe "Katana" Dual Heat Pipe CPU Cooler (SCKTN-1000)
Scythe "Mine" Heat Pipe CPU Cooler (SCMN-1000)
Scythe "Ninja" Heat Pipe CPU Cooler (SCNJ-1000P)
Scythe "Samurai Z" Dual Heat Pipe CPU Cooler (SCSMZ-1000)
Now let the elimination begin!
I tried to get all the ones that definately wont fit... but I may have missed some... I would have gone through and read the noise outputs, then reduce the list down... but its time for bed...
I hope this helps! This is what I do...
Then I go through and slowly pick them out... Price, Height, Noise... Then lastly Reviews, and well if you must Forum users... But we are not always objective or upto date... Its also good to own a subscription to Maximum PC... plus its a GREAT read.
Mike
