Hi, so recently my 1TB HDD that i have mostly everything on appears to be dieing so im considering upgrading it to a SSD to run my OS and Games off of then putting everything else onto my other 1TB HDD, Problem is i dont have that great of knowledge of computer hardware so i'm quite stumped as to what size SSD would be best and which SSD would be compatible with my current computer specs.
My 1TB HD that is going bad is a WD 64Mb SATA 3 HD, Would upgrading it to SSD be worth it? or should i just wait until i get my 1TB HD replaced from RMA?
If it would be a good upgrade could someone recommend a compatible, Reliable, and easy to install SSD thats under $300.
I'm guessing all the W7 OS stuff + Updates/Drivers will take about 20-40gb then would like atleast 60-100gb for some apps and games to run off it.
This is the SSD i was looking at buying http://www.newegg.com/Product/Product.aspx?Item=N82E16820233268
but im afraid having to update the firmware might end up baffling me and ill end up screwing up the whole SSD.
My current specs are
ASUS P6X58D Premium Motherboard Intel X58
Powercolor 5870 Rad GPU
Intel i7 930
3x i7 DDR3 Corsair 2GB Ram
Also when i install a new HDD/SSD do i need put it into a computer with the OS already installed then partition and format then install the OS onto it?
Intel i7 930
