[SOLVED] looking for something to protect my PC from power issues
mrb00ce
334
7
4,695
I'm looking for something to protect my PC from power fluctuations and low voltages. On a budget so can anyone suggest something?
I don't want to use my system when the power cuts out i just want enough time to shut the PC down and a UPS that can protect my PC.
That's the very reason for having a UPS. Most are already line-interactive (fancy speak for having a built-in AVR) as well as having surge suppression circuits.
The next step is to find the right-sized UPS for the amount of power your computer consumes and for how long you want the UPS to support it so you'll have enough time to do a proper shutdown.
A surge protector
15D974_AW01
Seconding @Gam3r01
A UPS - yes.
But do not plan to use the UPS to keep gaming or working for very long. The purpose of a UPS is to allow you to gracefully shutdown the system without losing or corrupting data.
What is your budget?
The cost of a UPS increases with the time that it must provide power to the supported devices.
And surge protection is not "forever". A surge protector can only take so many hits (Joules) before becoming ineffective.
Especially those "surge protectors" commonly found on sale and/or in discount bins.
Seconding @Gam3r01
A UPS - yes.
"I don't want to use my system when the power cuts out i just want enough time to shut the PC down and a UPS that can protect my PC. "
Excellent - all the better.
Hopefully all you need is 4 or 5 minutes to gracefully and properly shutdown the PC. Much less expensive than trying to run for an hour or so. Which may be moot any way if there is a general power outage and all ISP connections and devices are down.
Look for product reviews for UPS's available in your area.
Or UPS's that you can be certain of being able to order and then receive.
Read UPS User Guides/Manuals. Visit manufacturer websites to read Forums and FAQ's. Look for what is said and what is not said.
Lastly: Backups. Ensure that you have an active and ongoing process to back up your computer OS (image/clone) and data.
Just in case......
