[SOLVED] Looking for suitable Power Supply for PC
Dec 30, 2018
hi guys, i need some help. i want to know which power supply i need for my pc if my spec is :
IntelCore i3-8100 3.6 GHZ
ASUS socket 1151 Prime B360M-A
ZOTAC GeForce GTX 1060 AMP Core Edition 3GB DDR5
Kingston HX432C18FB2/8 8GB Hyperx Fury DDR4
and i use for gaming and sometimes do some 3D rendering works
Thanks for your answer..
Corsair CX450 is the best power supply for the least amount of cost.
Power Supply: Corsair - CX (2017) 450 W 80+ Bronze Certified ATX Power Supply ($44.89 @ OutletPC)
These are good if you want some room to upgrade your GPU, but still stay on a budget.
Power Supply: SeaSonic - EVO Edition 620 W 80+ Bronze Certified Fully-Modular ATX Power Supply ($59.90 @ B&H)
Power Supply: Corsair - CX (2017) 650 W 80+ Bronze Certified ATX Power Supply ($59.99 @ Amazon)
Power Supply: Corsair - CX (2017) 750 W 80+ Bronze Certified ATX Power Supply ($59.99 @ Amazon)
These are good for highest quality and durability. I'd go for the EVGA G3 750 if you wanted one of these.
Power Supply: SeaSonic - FOCUS Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply ($68.79 @ B&H)
Power Supply: Corsair - TXM Gold 650 W 80+ Gold Certified Semi-Modular ATX Power Supply ($69.98 @ Amazon)
Power Supply: Corsair - RMx (2018) 550 W 80+ Gold Certified Fully-Modular ATX Power Supply ($74.99 @ Newegg Business)
Power Supply: EVGA - SuperNOVA G3 750 W 80+ Gold Certified Fully-Modular ATX Power Supply ($79.99 @ Amazon)
