Looking for upgrade advice for gaming rig (300-400$ range, internal parts mostly)
FDru
13
In the past I've had trouble with getting parts that fit together properly, so am hoping I will have better luck asking here from builders who are more knowledgeable.
Currently running a 2.9 ghz dual core with GeForce GTX 560 Ti which are starting to show their age, and I'm looking to upgrade them as well as probably the psu and a new HDD. Top of the line is not important, mainly I'd like something with decent performance that's stable and will likely not need to be replaced for a long while.
The most resource intensive games I play are X3 series and some 2D building games with complex lighting/massive object counts like Darkout, Starbound, Terraria, etc (which don't need insane power but still tend to slow down some on my current rig).
If it matters I'm using Win 7 with a pending Win 10 update.
The parts absolutely needing upgraded are:
Graphics
Processor
Motherboard
Optionally may need upgrades for:
Memory (I have two 4gb DDR3 sticks; it's okay but if can get some better ones for cheap that would be nice)
Power Supply (not sure what my current psu is, but I believe it has just enough power to run what I have)
Tower (my current tower is a bit small, and has some trouble fitting the newer video cards)
Additionally I was considering getting a faster hard drive, either an SSD or hybrid. Truthfully this is just to help with save/load times in Distant Worlds and X3 (and other games with increasingly large save files) so it doesn't need to be extravagant but this is a part I'm willing to spend extra on if it's going to be a good long-term investment.
If I can get all (or most of) of the above under 400$ that would be amazing, but I may be able to go a bit over if there's a good compromise.
Thanks in advance.
Here is is! Its a bit more than your price, but it'll perform much better than a 2.9ghz dual core and a 560ti.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($199.99 @ Micro Center)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard ($81.89 @ OutletPC)
Video Card: EVGA GeForce GTX 950 2GB Superclocked Video Card ($159.99 @ Amazon)
Total: $441.87
Generated by PCPartPicker 2015-08-21 14:52 EDT-0400
The GTX950 has give or take the same amount of power as the other still-new GTX960.
The i5 will also be a massive upgrade in almost everything.
Hi SeriouslyStache. Thanks for the suggestions, but that seems a bit more pricey on the individual parts than I was hoping for. It really doesn't leave any $ for anything else I might need (I did have my heart set on a new HD). I will definitely keep it in mind, though.
If by HD you mean Hard Drive, I have you covered.
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor ($99.99 @ Micro Center)
Motherboard: Asus Z87-A ATX LGA1150 Motherboard ($80.98 @ Newegg)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($86.99 @ SuperBiiz)
Total: $427.95
Generated by PCPartPicker 2015-08-21 21:03 EDT-0400
It isn't an SSD or Hybrid 😛 (sorry if the term HD threw you off, but I explained that in my original post). However I can probably find one in that price range, so I'll see if the other parts you suggested meet my desires and go from there.
Thanks again.
Im determined. Lol
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($80.98 @ Amazon)
Total: $421.94
Generated by PCPartPicker 2015-08-22 11:34 EDT-0400
