Looking for USB mixer/interface for studio monitors
Hello everyone,
I am looking for an audio mixer to tweak the levels of 2-3 inputs going to a single output. I am looking for something pretty specific and will start by explaining my setup and what inputs/outputs I need.
Current setup:
2x JBL LSR 305 (Input: XLR)
1x JBL LSR 310s (Input: 1/4" TRS Output: XLR)
Denon DP300F (Output: L+R RCA)
PC (Output: USB)
PS4 (Output: Toslink)
Focusrite Scarlet 6i6
So what I would like to be able to do is be using either the PC or PS4 while using the turntable and manually dictate how much of each is being output through the studio monitors. IE: 30% turntable, 70% PS4.
So what I need on a device is at least L/R 1/4" TRS inputs OR RCA L/R inputs, a USB input, and either a toslink, mini toslink, or s/pdif input. On top of that it will need the ability to either individually control volume per channel or control the split mix of each. If you know of anything that can do this or if there is a better way to go about this using my 6i6 please give me any insight you can, I am very new to the high end audio scene.
Thank you
You may be able to do it this way.
The 6i6 has spdif input so you can convert the PS4 toslink to coax digital and connect it.
The TT can be connected to 2 line level inputs on the 6i6 since it has a phono preamp built in..
The 6i6 USB connection may be able to get PC audio into the 6i6 as well as the other sources into the PC.
Then you mix with software or the PC audio mixer.
https://github.com/audiorouterdev/audio-router
http://www.chevolume.com/
https://www.vb-audio.com/Cable/index.htm
