Looking for Water cooling kit with specific characteristics
karl_azytzeen
31
Hi all.
Im looking for a Watercooling kit wich has some part that are must to later be expanded at the cheapest cost.
The characteristits im lloking at are:
-XSPC Raystorm CPU waterblock for Intel 115x or performance equivalente.
-D5 Pump (vario or non-vario isnt trouble cause it will ve voltage regulated)
- 120 double rad, performace oriented for low noise fans.
-Bay reservoirs just if they provide something over any other, otherwise Pipe reservoir is preferred (AS i had NZXT phantom it is novisible most time, but if is cheaper i had no trouble going for it)
I will use this to cool a 4770k with average OC and VRM. Later when add more radiator i will expand to GPU/s.
If helps, in the future i willpalce an standalone reservoir in the top of the case moding it to be visible is horizontal position. To keep circuit efficency i think to have this in to a separeted circuit and using a flow meter on the main circuit to provide control signal for this secondary "fancy" circuit.
Not sure if you have looked at either the Swiftech H220 or H320, but they come as all-in-one coolers and have the capability to be expanded later.
The res is built into the radiator for the H220 and the pump is built into the CPU block and is strong enough for bigger loops.
Currently $100 at NCIX: http://www.ncixus.com/products/?sku=79583
I currently have the H320 (same as H220 except has a triple radiator) and is good for keeping overclocks cool.
Hi! thanks for the fast response
I had decided to dont go with AIO, cause i will add 1 or 2 more radiators, VRM and NB block + VGA, so anyway i will need to replace it, also the 240rad is placed in the rear fan outside.
At this moment an XSPC kit 240 is the one that fits mi requeriments better... any other sugestion??
Txs
