Looking if somebody can help/point me right direction
HateFate
4
so i need that you guys tell me if this pc build is any good and worth 735 Brit pounds.
Thanks in forward!
Case : Zalman Z11+ Black Tower Case + 2 x 120mm Blue Led Fans
Power Supply : Aerocool Certified 80 Plus Bronze 850W Power Supply
Motherboard : Gigabyte 78LMT-USB3
CPU : AMD FX 8350 Eight Core CPU (turbo 4.2Ghz)
Hard Drive : 1tb Sata Hard Drive
Memory : 16gb DDR3 1600mhz Branded Memory
Graphics Card : Nvidia GTX 980 4GB (Tripple screen support 3D surround)
Optical Drive : 24x Dual Layer DVD Writer
Warranty : 12 Months Return To Base (Parts & Labour)
Connections : 6 x USB 2.0 / 2 x USB 3.0 / LAN / Sound
hello thanks for your reply but can i ask you this you made will run all games on ultra settings ? and will it run games for other 3-4 years? my budget is around 700-800 if with monitor could you point me something realy nice for that money. sorry i am not realy good at this but ima starting to learn :)
ps. i dont care if there is fancy looks or ugly all i care it runs and is stable,
pss. it will be mainly for newest games and mmos.
Well sometimes wants and what reality can give are different. Your budget with a monitor is not going to allow you to max all games on ultra. You can come up with more money, or settle for less performance.
u just killed my reality :) so about how much for budget good gaming pc ? with upgrade compability latter on. could i see that build. Thank you!
