Question Looking to build an open loop cooling computer beast, What would be the best choices for the parts below?
guspowergunner
AMD Ryzen 9 3950X 3.5 GHz 16-Core Processor
Asus GeForce RTX 2070 SUPER 8 GB STRIX GAMING Advanced Video Card
I wanna build a computer with these in mind for a custom water cooling setup but know little to nothing about the subject, so what would be the best parts to fit the two listed above?
Phaaze88
Illustrious
Ambassador
I suggest you start there.
The statement,'I wanna do custom loop, but don't know much about it', won't fly here; that'll just get this thread ignored and buried under newer ones.
You gotta do your homework with this subject. Custom loop isn't as simple with things like 'best parts'. There's also maintenance, the part that ends up turning most people away from it - beside cost.
If you are looking for the quick and easy method, then use AIOs instead.
