V viktory36 Reputable Mar 6, 2014 42 0 4,540 Jun 26, 2015 #1 Would be great if the monitor could be found on flipkart.com or amazon.in I've tried reading reviews but I'm afraid of being shilled into buying stuff not worth it. As always, thanks!
Solution guanyu210379 Jun 26, 2015 Rs20k? Well, I have this U2412M http://www.flipkart.com/dell-u2412m-24-inch-led-backlit-lcd-monitor/p/itmd9n68nbncjevh?pid=MOND9N2RQWMWXDKY&ref=L%3A-3104385033737910108&srno=b_5 I bought it not from India of course but I have that monitor. It is an 60Hz 5ms IPS monitor. This monitor is good for gaming too, just not as smooth as those TN panels with over 75Hz refresh rate. That monitor was bought 3 years ago and starting 3 weeks ago I am using it only as extension monitor after my XB270HU arrived.
guanyu210379 Illustrious Mar 30, 2007 7,681 25 38,115 Jun 26, 2015 Solution #2 Rs20k? Well, I have this U2412M http://www.flipkart.com/dell-u2412m-24-inch-led-backlit-lcd-monitor/p/itmd9n68nbncjevh?pid=MOND9N2RQWMWXDKY&ref=L%3A-3104385033737910108&srno=b_5 I bought it not from India of course but I have that monitor. It is an 60Hz 5ms IPS monitor. This monitor is good for gaming too, just not as smooth as those TN panels with over 75Hz refresh rate. That monitor was bought 3 years ago and starting 3 weeks ago I am using it only as extension monitor after my XB270HU arrived. Upvote 0 Downvote Solution
V viktory36 Reputable Mar 6, 2014 42 0 4,540 Jun 26, 2015 #3 Alright I'll get that one then, thanks. Upvote 0 Downvote
O ONKI Reputable May 23, 2014 547 0 5,160 Jun 27, 2015 #4 if u use it for gaming then go for Benq xl2420z 144 hz monitor but its priced a lil higher on ur budget. when i first bought like 6 months back it was 24k im sure if you buy from a shop rather than flipkart u will get it for 22 or 23k Upvote 0 Downvote
