So recently I've been getting inspired by all these mod rigs and build logs around the place and am considering to do my first water cooling loop. I'm not talking slapping on a h100 or something like that i want to go proper built loop.
Now as a beginner i am only looking at starting out slow so I've been having a look at things like the xspc raystorm kits, only around the rs240 series, and have some questions on what i should do.
First, is it worth buying compression fittings to replace the six barb fittings that come with the kit and are barbs less safe/ less prone to leaks as compression fittings or is it just that compression fittings are easier to release?
Second thing is what necessities do i need that don't usually come with kits, eg. do i need a kill coil and do things like clean the loop out before installation with distilled water?
Extra: i intend to either build this kit up or carry it over to other builds so a vga cooler may come later but its just cpu for now.
Any help and suggestions would be appreciated.
Thanks, Jake.
Thanks, Jake.
