Hello,
I will be ordering the following case, Cooltek Coolcube ITX case --> http://www.cooltek.de/en/cubes/coolcube/2/coolcube
Inside I will put a h110m asrock motherboard, i3 6100 and a be quiet system power 8 500w PSU and ofc ssd & hdd. There is a chance a mini gtx 1050ti zotac will find its place in the case later on.
I want to maximize airflow / help cool everything as much as possible (as there is little space between each component and as such there will be more heat generated).
The case has a perforated side panel and optional 4x 40 mm rear fan mount.
I was planning on purchasing the optional 4 fans and installing them. So my question is if I should mount them at all and if yes, how?
They can only be installed in a vertical row.
Thoughts, expert advice, etc.... is welcomed and much appreciated.
Thanks in advance
PS I'm ordering tomorrow (Tuesday, 25.10.2016) so please be quick and precise
Thanks in advance
