S spectre88 Feb 26, 2020 9 1 15 Apr 29, 2020 #1 processor- i9 9900k motherboard- asus prime z390-a lga 1151 will these work well together or should i find another board?
Solution A A AppleGwava Apr 29, 2020 A quick google search shows that they are compatible https://www.asus.com/us/Motherboards/PRIME-Z390-A/HelpDesk_CPU/ The z390 is the highest end chipset by intel (Currently) for the i9 9900k You should do fine with this combination
A AppleGwava Reputable Jul 11, 2016 714 9 5,365 Apr 29, 2020 Solution #2 A quick google search shows that they are compatible https://www.asus.com/us/Motherboards/PRIME-Z390-A/HelpDesk_CPU/ The z390 is the highest end chipset by intel (Currently) for the i9 9900k You should do fine with this combination Upvote 0 Downvote Solution
logainofhades Titan Moderator Apr 27, 2009 37,536 3,210 143,290 Apr 29, 2020 #3 Yes they will work, but be advised that 10th gen is coming soon, so you are left without an upgrade path. Upvote 0 Downvote
