Hello, I've been looking into getting into water cooling for quite some time but I'm somewhat on the fence and maybe some of you can steering me in the right direction. One of my concerns is that my case I'm using a Thermaltake Armor + Full tower it's not the best designed case it's somewhat roomy but the PSU is mounted at the top so I have no way of mounting a rad up at the top really so I would have to get creative with mounting everything.
I was looking at the Raystorm 750 Rx360 originally then I saw the EX 360 kit with the D5 pump become available although being almost $100 more than the 750 kit from what I was able to gather the D5 pump is better and I would be willing to pay for a more reliable pump. The other thing although I know most of the hardcore water cooling guys are not fond of the AIO, but with the release of the Swiftech H220 it's made me consider it as a option I know can't really compare it to a real water cooling loop but I believe from what I'm able to gather it's a pretty good unit.
As far as the reason to water cool well I've just always wanted too in addition yes I do overclock not to the extreme but I would like to push my system a little more than I have it now in the future. I also plan to water cool my 7870 , I want to do this with the hope of also reducing the noise of my setup too having the DCUII cooling solution on the GPU, the big 230mm side fan, two 140mm case fans and the CPU fan all make a pretty big racket.
Between the 750 RX360 or EX360 /w D5 pump or H220 what would be the best option for my needs ?
Is this EK 7870 block any good ?
http://www.frozencpu.com/products/16422/ex-blc-1165/EK_Radeon_7870_GTX_VGA_Liquid_Cooling_Block_-_Nickel_Acetal_CSQ_EK-FC7870_-_Nickel_Acetal.html?tl=g30c309s1705
My case:
http://www.thermaltakeusa.com/products-model.aspx?id=C_00000091
RX360kit
http://www.frozencpu.com/products/16894/ex-wat-222/XSPC_Raystorm_750_RX360_Extreme_Universal_CPU_Water_Cooling_Kit_w_Free_Dead-Water.html?tl=g30c83s137
Ex360 kit
http://www.frozencpu.com/products/16071/ex-wat-211/XSPC_Raystorm_EX360_Universal_CPU_Water_Cooling_Kit_w_D5_Variant_Pump_Included_and_Free_Dead-Water_.html?tl=g30c83s137
H220
http://www.frozencpu.com/products/18290/ex-wat-242/Swiftech_H220_Compact_Drive_II_Plug-and-Play_Liquid_Cooling_System.html
My case:
RX360kit
Ex360 kit
H220
