Hi,
I have the corsair h75Hi and the Gigabyte X99-UD4 MB.
I tried to install the cooling unit, as I understand no special adapter should be used for this MB, I placed the screw on top of the MB and then placed the cooling unit, but the screws on the plate of the cooling unit didnt match the screws I mounted on the MB.
I bent the plate a little bit and used a little bit of force to place the 4 screws , but still the cooling unit feels a bit loose and shsaky.
anyone faced this problem ? what can I do ? Is it ok to leave the cooling unit this way ?
Thanks
Thanks
