Loosing wireless after establishing a connection
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I am using a ViewSonic Airpanel to remotely access a laptop in peer-to-peer
wireless mode.
Everything seems to work fine - I am logged into my laptop as a domain user
and I am able to connect via the peer to peer wireless using the same user
name and password. I go through all the connection screens - the laptop
becomes 'locked' when the remote desktop comes up on the Airpanel - then
after a couple of seconds, the air panel looses the wireless connection. It
seems that as soon as the laptop becomes locked, it shuts down the wireless
connection.
Does anyone have any ideas on this?
OK, I read a few other posts and found the problem. My laptop was set up to
use it's own wireless connection management software, and not the built in
wireless management stuff that is native within XP. I simply told the laptop
to use the microsoft client to manage my wireless connections, and all is
well.
> wireless mode.
> connection.
