Really need some help with this 3 month old problem. Haven't been able to use the PC at all apart from diagnosing it and dealing with at this point 100s of shutdowns and hard crashes. I've done everything I can possibly think of. I've RMA'd the PSU, GPU, CPU, and RAM (**** newegg, GPU RMA done through gigabyte which was nightmarish). None of those are the culprits, but it's important to note that the kernel power 41 primarily occurs when the CPU is under load, even the brand new RMA'd one (which is why I thought it was a CPU problem, silly me...).
Temps have always been low ~25C and GPU ~30C. Other times the system just crashes when loading something, like after I click enter to login desktop, or opening chrome or edge. I've ruled out the M2 1TB drive after downloading WD's software and diagnosing/updating, which leaves either the 2TB SSD or motherboard. Bios is latest version, all drives (ALL) have been inspected and updated, latest windows, over a dozen factory resets (windows downloaded directly from their microsoft servers), no OC, no XMP, everything stock, multiple reseats, new cables, complete teardown and rebuild, still kernel error 41 hard black screen crashes, then reboots.
I don't think it's the 2tb drive because it seems to run seemingly fine for the most part as long as I don't have CPU intensive tasks open or running. But this still occurs even with the new CPU sent from Intel so I'm at a loss. Before I purchase a new mobo, perhaps some of you have some ideas that I can implement to further test this because this is unreal and ive lost my ******* mind over this. if this didn't cost a lot I would have surely smashed it, run over it, or thrown it off my balcony.
Another interesting thing is windows is installed on disk C (WD 1TB m2), but my bios boots from disk D (2TB SSD) even though windows isn't installed on it (0mb is on the drive). When I unplug and disconnect the 2TB SSD, PC boots into bios only and unable to boot windows.
Here is the build:
Here is the build:
