On my work PC, I have a 160 GB drive (storage, not boot or O/S) that had two partitions. One was 30 GB at the beginning of the drive and the other was the remainder of the drive. Having had the best of luck with GParted, I decided to delete the smaller first partition using the Disk Management tool in WinXP (Pro SP3) and then boot onto my GParted CD and resize the second larger partition to the beginning of the drive.
Foolishly, I didn't take the time to do a full prior backup, falsely reasoning that it wasn't worth adding over 30 minutes to a 2 or 3 minute job. As luck would have it, less than a minute into the operation there was an interruption of the power to the drive, killing the operation. I was not able to retry or resume as there was now a very messed up MFT.
I already had GetDataBack for NTFS installed on the boot drive, so I started it up and found that there was a recoverable MFT on the drive, but it was only of the files that had been on the originally deleted partition. No MFT was available for the files Ihad intended to keep on the larger partition.
Fortunately, I have a backup of all the mission critical files for my work, but I had many personal files on the drive that had not been backed up. I know the data is intact, but I'm not sure if there's any way to get the long filenames back during the recovery process. If it can't be done, it would be such a daunting task to proper filenames put back on all those files (must be over 60,000 of them!) that I'd probably give up.
Can anyone advise me on what my possibilities are? Can I get those files back with their original names properly associated?
Thank you,
Tim
Thank you,
Tim
