Lost remote control for my computer and can no longer access settings.
kaio37k
239
S, I lost my remote control for my Gateway ZX6961
and now I can't go t settings.
I'm trying to make it my primary monitor for my desktop, and to do this I need settings.
Any help would be great, thanks!
By remote control, do you mean, the same sort of infrared remote control device that you would use on a television set?
Provided you are using Windows 7 and have a mouse plugged in, using your computer's mouse, you should be able to single right-mouse click on a blank portion of the Windows Desktop and choose "Screen resolution" from the context menu. From there you should have the option for choosing a primary screen.
Yes, remote control; but my goal is to use my All-in-One as my primary monitor for a separate desktop.
If it helps I have both HDMI and VGA.
Ok, will do that. Thank you!
