[SOLVED] Lost sound after a kernel bsod
Jan 23, 2020
9
I got new ram and I got a karnel bsod. Now I don't have sound. There are no devices under audio but my microphone works perfectly. In device manager High definition Audio Controller has an error:
This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful.
Device PCI\VEN_8086&DEV_A348&SUBSYS_86C71043&REV_10\3&11583659&0&FB had a problem starting.
Driver Name: hdaudbus.inf
Class Guid: {4d36e97d-e325-11ce-bfc1-08002be10318}
Service: HDAudBus
Lower Filters:
Upper Filters:
Problem: 0xA
Problem Status: 0xC0000001
What are specs of the PC?
What ram did you buy?
hdaudbus.inf is a Microsoft driver.
Just check windows out:
right click start button
choose powershell (admin)
type SFC /scannow and press enter
once its completed, copy/paste this command into same window:
Repair-WindowsImage -Online -RestoreHealth
and press enter
SFC fixes system files, second command cleans image files, re run SFC if it failed to fix all files and restart PC
replace ram, random windows driver plays up..
Try running memtest86 on each of your ram sticks, one stick at a time, up to 4 passes. Only error count you want is 0, any higher could be cause of the BSOD. Remove/replace ram sticks with errors. Memtest is created as a bootable USB so that you...
and press enter
Try running memtest86 on each of your ram sticks, one stick at a time, up to 4 passes. Only error count you want is 0, any higher could be cause of the BSOD. Remove/replace ram sticks with errors. Memtest is created as a bootable USB so that you don’t need windows to run it
I got the error 87 after using the repair command. And this logs:
2020-06-07 03:44:43, Info DISM PID=8928 TID=8124 Scratch directory set to 'C:\Users\krist\AppData\Local\Temp\'. - CDISMManager:😛ut_ScratchDir
2020-06-07 03:44:43, Info DISM PID=8928 TID=8124 DismCore.dll version: 10.0.18362.1 - CDISMManager::FinalConstruct
2020-06-07 03:44:43, Info DISM Initialized Panther logging at C:\WINDOWS\Logs\DISM\dism.log
2020-06-07 03:44:43, Info DISM PID=8928 TID=8124 Successfully loaded the ImageSession at "C:\WINDOWS\system32\Dism" - CDISMManager::LoadLocalImageSession
2020-06-07 03:44:43, Info DISM DISM Provider Store: PID=8928 TID=8124 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2020-06-07 03:44:43, Info DISM DISM Provider Store: PID=8928 TID=8124 Failed to get and initialize the PE Provider. Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2020-06-07 03:44:43, Info DISM DISM Provider Store: PID=8928 TID=8124 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2020-06-07 03:44:43, Info DISM DISM Manager: PID=8928 TID=8124 Successfully created the local image session and provider store. - CDISMManager::CreateLocalImageSession
2020-06-07 03:44:43, Info DISM DISM.EXE:
2020-06-07 03:44:43, Info DISM DISM.EXE: <----- Starting Dism.exe session ----->
2020-06-07 03:44:43, Info DISM DISM.EXE: Host machine information: OS Version=10.0.18363, Running architecture=amd64, Number of processors=6
2020-06-07 03:44:43, Info DISM DISM.EXE: Dism.exe version: 10.0.18362.1
2020-06-07 03:44:43, Info DISM DISM.EXE: Executing command line: DISM /Online /Cleanup-Image /CheckHealth
2020-06-07 03:44:43, Info DISM DISM Provider Store: PID=8928 TID=8124 Connecting to the provider located at C:\WINDOWS\system32\Dism\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:43, Info DISM DISM Manager: PID=8928 TID=8124 physical location path: C:\ - CDISMManager::CreateImageSession
2020-06-07 03:44:43, Info DISM DISM Manager: PID=8928 TID=8124 Event name for current DISM session is Global\{93A5BB8D-6463-4DB2-B40C-471303DDDEB5} - CDISMManager::CheckSessionAndLock
2020-06-07 03:44:43, Info DISM DISM Manager: PID=8928 TID=8124 Create session event 0x1f8 for current DISM session and event name is Global\{93A5BB8D-6463-4DB2-B40C-471303DDDEB5} - CDISMManager::CheckSessionAndLock
2020-06-07 03:44:43, Info DISM DISM Manager: PID=8928 TID=8124 Copying DISM from "C:\WINDOWS\System32\Dism" - CDISMManager::CreateImageSessionFromLocation
2020-06-07 03:44:43, Info DISM DISM Manager: PID=8928 TID=8124 Successfully loaded the ImageSession at "C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B" - CDISMManager::LoadRemoteImageSession
2020-06-07 03:44:43, Info DISM DISM Image Session: PID=8088 TID=6452 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore
2020-06-07 03:44:43, Info DISM DISM Provider Store: PID=8088 TID=6452 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect
2020-06-07 03:44:43, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:43, Info DISM DISM OS Provider: PID=8088 TID=6452 Defaulting SystemPath to C:\ - CDISMOSServiceManager::Final_OnConnect
2020-06-07 03:44:43, Info DISM DISM OS Provider: PID=8088 TID=6452 Defaulting Windows folder to C:\Windows - CDISMOSServiceManager::Final_OnConnect
2020-06-07 03:44:43, Info DISM DISM Provider Store: PID=8088 TID=6452 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect
2020-06-07 03:44:43, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:43, Info DISM DISM Provider Store: PID=8088 TID=6452 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2020-06-07 03:44:43, Warning DISM DISM Provider Store: PID=8088 TID=6452 Failed to load the provider: C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\PEProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2020-06-07 03:44:43, Info DISM DISM Provider Store: PID=8088 TID=6452 Failed to get and initialize the PE Provider. Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2020-06-07 03:44:43, Info DISM DISM Provider Store: PID=8088 TID=6452 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2020-06-07 03:44:43, Info DISM DISM Manager: PID=8928 TID=8124 Image session successfully loaded from the temporary location: C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B - CDISMManager::CreateImageSession
2020-06-07 03:44:43, Info DISM DISM.EXE: Target image information: OS Version=10.0.18363.836, Image architecture=amd64
2020-06-07 03:44:43, Info DISM DISM.EXE: Image session version: 10.0.18362.1
2020-06-07 03:44:43, Info DISM DISM Provider Store: PID=8088 TID=6452 Getting the collection of providers from an image provider store type. - CDISMProviderStore::GetProviderCollection
2020-06-07 03:44:43, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\CbsProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:43, Info DISM DISM Provider Store: PID=8088 TID=6452 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:43, Info CSI 00000001 Shim considered [l:125]'\??\C:\WINDOWS\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.18362.772_none_5f13f94c58ff41d3\wcp.dll' : got STATUS_OBJECT_PATH_NOT_FOUND
2020-06-07 03:44:43, Info CSI 00000002 Shim considered [l:122]'\??\C:\WINDOWS\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.18362.772_none_5f13f94c58ff41d3\wcp.dll' : got STATUS_SUCCESS
2020-06-07 03:44:43, Info DISM DISM Package Manager: PID=8088 TID=6452 Finished initializing the CbsConUI Handler. - CCbsConUIHandler::Initialize
2020-06-07 03:44:43, Info DISM DISM Package Manager: PID=8088 TID=6452 CBS is being initialized for online use. More information about CBS actions can be located at: %windir%\logs\cbs\cbs.log - CDISMPackageManager::Initialize
2020-06-07 03:44:44, Info DISM DISM Package Manager: PID=8088 TID=6452 Loaded servicing stack for online use only. - CDISMPackageManager::CreateCbsSession
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\MsiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\IntlProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\IBSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\DmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:44, Info CSI 00000001 Shim considered [l:125]'\??\C:\WINDOWS\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.18362.772_none_5f13f94c58ff41d3\wcp.dll' : got STATUS_OBJECT_PATH_NOT_FOUND
2020-06-07 03:44:44, Info CSI 00000002 Shim considered [l:122]'\??\C:\WINDOWS\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.18362.772_none_5f13f94c58ff41d3\wcp.dll' : got STATUS_SUCCESS
2020-06-07 03:44:44, Info DISM DISM Driver Manager: PID=8088 TID=6452 Further logs for driver related operations can be found in the target operating system at %WINDIR%\inf\setupapi.offline.log - CDriverManager::Initialize
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\UnattendProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\SmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:44, Warning DISM DISM Provider Store: PID=8088 TID=6452 Failed to load the provider: C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\EmbeddedProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\AppxProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\ProvProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\AssocProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\GenericProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\OfflineSetupProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\SysprepProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\TransmogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:44, Info DISM DISM Transmog Provider: PID=8088 TID=6452 Current image session is [ONLINE] - CTransmogManager::GetMode
2020-06-07 03:44:44, Info DISM DISM Transmog Provider: PID=8088 TID=6452 Audit Mode: [No] - CTransmogManager::Initialize
2020-06-07 03:44:44, Info DISM DISM Transmog Provider: PID=8088 TID=6452 GetProductType: ProductType = [WinNT] - CTransmogManager::GetProductType
2020-06-07 03:44:44, Info DISM DISM Transmog Provider: PID=8088 TID=6452 Product Type: [WinNT] - CTransmogManager::Initialize
2020-06-07 03:44:44, Info DISM DISM Transmog Provider: PID=8088 TID=6452 Product Type ServerNT : [No] - CTransmogManager::Initialize
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\02894B8D-186D-40FB-8E40-9CB8C6EFCD4B\SetupPlatformProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:44, Info DISM DISM.EXE: Got the collection of providers. Now enumerating them to build the command table.
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Log Provider
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: OSServices
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Package Manager
2020-06-07 03:44:44, Info DISM DISM.EXE: Succesfully registered commands for the provider: DISM Package Manager.
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: MsiManager
2020-06-07 03:44:44, Info DISM DISM.EXE: Succesfully registered commands for the provider: MsiManager.
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: IntlManager
2020-06-07 03:44:44, Info DISM DISM.EXE: Succesfully registered commands for the provider: IntlManager.
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: IBSManager
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: DriverManager
2020-06-07 03:44:44, Info DISM DISM.EXE: Succesfully registered commands for the provider: DriverManager.
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Unattend Manager
2020-06-07 03:44:44, Info DISM DISM.EXE: Succesfully registered commands for the provider: DISM Unattend Manager.
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: SmiManager
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: AppxManager
2020-06-07 03:44:44, Info DISM DISM.EXE: Succesfully registered commands for the provider: AppxManager.
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: ProvManager
2020-06-07 03:44:44, Info DISM DISM.EXE: Succesfully registered commands for the provider: ProvManager.
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: AssocManager
2020-06-07 03:44:44, Info DISM DISM.EXE: Succesfully registered commands for the provider: AssocManager.
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: GenericManager
2020-06-07 03:44:44, Info DISM DISM.EXE: Succesfully registered commands for the provider: GenericManager.
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: OfflineSetupManager
2020-06-07 03:44:44, Info DISM DISM.EXE: Succesfully registered commands for the provider: OfflineSetupManager.
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: SysprepManager
2020-06-07 03:44:44, Info DISM DISM.EXE: Succesfully registered commands for the provider: SysprepManager.
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: Edition Manager
2020-06-07 03:44:44, Info DISM DISM.EXE: Succesfully registered commands for the provider: Edition Manager.
2020-06-07 03:44:44, Info DISM DISM.EXE: Attempting to add the commands from provider: SetupPlatformManager
2020-06-07 03:44:44, Info DISM DISM.EXE: Succesfully registered commands for the provider: SetupPlatformManager.
2020-06-07 03:44:44, Info DISM DISM Package Manager: PID=8088 TID=6452 Processing the top level command token(cleanup-image). - CPackageManagerCLIHandler:😛rivate_ValidateCmdLine
2020-06-07 03:44:44, Info DISM DISM Package Manager: PID=8088 TID=6452 Attempting to route to appropriate command handler. - CPackageManagerCLIHandler::ExecuteCmdLine
2020-06-07 03:44:44, Info DISM DISM Package Manager: PID=8088 TID=6452 Routing the command... - CPackageManagerCLIHandler::ExecuteCmdLine
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Found the PE Provider. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Finalizing the servicing provider(DISM Package Manager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Package Manager: PID=8088 TID=6452 Finalizing CBS core. - CDISMPackageManager::Finalize
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Disconnecting Provider: DISM Package Manager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Finalizing the servicing provider(MsiManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Disconnecting Provider: MsiManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Finalizing the servicing provider(IntlManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Disconnecting Provider: IntlManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Finalizing the servicing provider(IBSManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Disconnecting Provider: IBSManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Finalizing the servicing provider(DriverManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Disconnecting Provider: DriverManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Finalizing the servicing provider(DISM Unattend Manager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Disconnecting Provider: DISM Unattend Manager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Finalizing the servicing provider(SmiManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Disconnecting Provider: SmiManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Finalizing the servicing provider(AppxManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Disconnecting Provider: AppxManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Finalizing the servicing provider(ProvManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Disconnecting Provider: ProvManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Finalizing the servicing provider(AssocManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Disconnecting Provider: AssocManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Finalizing the servicing provider(GenericManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Disconnecting Provider: GenericManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Finalizing the servicing provider(OfflineSetupManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Disconnecting Provider: OfflineSetupManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Finalizing the servicing provider(SysprepManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Disconnecting Provider: SysprepManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Finalizing the servicing provider(Edition Manager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Disconnecting Provider: Edition Manager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Finalizing the servicing provider(SetupPlatformManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Disconnecting Provider: SetupPlatformManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8088 TID=6452 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Manager: PID=8928 TID=8124 Closing session event handle 0x1f8 - CDISMManager::CleanupImageSessionEntry
2020-06-07 03:44:44, Info DISM DISM.EXE: Image session has been closed. Reboot required=no.
2020-06-07 03:44:44, Info DISM DISM.EXE: <----- Ending Dism.exe session ----->
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8928 TID=8124 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8928 TID=8124 Disconnecting Provider: FolderManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:44, Info DISM DISM Provider Store: PID=8928 TID=8124 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:44:57, Info DISM PID=11640 TID=11592 Scratch directory set to 'C:\Users\krist\AppData\Local\Temp\'. - CDISMManager:😛ut_ScratchDir
2020-06-07 03:44:57, Info DISM PID=11640 TID=11592 DismCore.dll version: 10.0.18362.1 - CDISMManager::FinalConstruct
2020-06-07 03:44:57, Info DISM Initialized Panther logging at C:\WINDOWS\Logs\DISM\dism.log
2020-06-07 03:44:57, Info DISM PID=11640 TID=11592 Successfully loaded the ImageSession at "C:\WINDOWS\system32\Dism" - CDISMManager::LoadLocalImageSession
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=11640 TID=11592 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=11640 TID=11592 Failed to get and initialize the PE Provider. Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=11640 TID=11592 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2020-06-07 03:44:57, Info DISM DISM Manager: PID=11640 TID=11592 Successfully created the local image session and provider store. - CDISMManager::CreateLocalImageSession
2020-06-07 03:44:57, Info DISM DISM.EXE:
2020-06-07 03:44:57, Info DISM DISM.EXE: <----- Starting Dism.exe session ----->
2020-06-07 03:44:57, Info DISM DISM.EXE: Host machine information: OS Version=10.0.18363, Running architecture=amd64, Number of processors=6
2020-06-07 03:44:57, Info DISM DISM.EXE: Dism.exe version: 10.0.18362.1
2020-06-07 03:44:57, Info DISM DISM.EXE: Executing command line: DISM /Online /Cleanup-Image /ScanHealth
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=11640 TID=11592 Connecting to the provider located at C:\WINDOWS\system32\Dism\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM Manager: PID=11640 TID=11592 physical location path: C:\ - CDISMManager::CreateImageSession
2020-06-07 03:44:57, Info DISM DISM Manager: PID=11640 TID=11592 Event name for current DISM session is Global\{4E41FDE4-1809-459F-A5F8-D741129955F1} - CDISMManager::CheckSessionAndLock
2020-06-07 03:44:57, Info DISM DISM Manager: PID=11640 TID=11592 Create session event 0x1f8 for current DISM session and event name is Global\{4E41FDE4-1809-459F-A5F8-D741129955F1} - CDISMManager::CheckSessionAndLock
2020-06-07 03:44:57, Info DISM DISM Manager: PID=11640 TID=11592 Copying DISM from "C:\WINDOWS\System32\Dism" - CDISMManager::CreateImageSessionFromLocation
2020-06-07 03:44:57, Info DISM DISM Manager: PID=11640 TID=11592 Successfully loaded the ImageSession at "C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860" - CDISMManager::LoadRemoteImageSession
2020-06-07 03:44:57, Info DISM DISM Image Session: PID=9844 TID=6108 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM OS Provider: PID=9844 TID=6108 Defaulting SystemPath to C:\ - CDISMOSServiceManager::Final_OnConnect
2020-06-07 03:44:57, Info DISM DISM OS Provider: PID=9844 TID=6108 Defaulting Windows folder to C:\Windows - CDISMOSServiceManager::Final_OnConnect
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2020-06-07 03:44:57, Warning DISM DISM Provider Store: PID=9844 TID=6108 Failed to load the provider: C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\PEProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Failed to get and initialize the PE Provider. Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2020-06-07 03:44:57, Info DISM DISM Manager: PID=11640 TID=11592 Image session successfully loaded from the temporary location: C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860 - CDISMManager::CreateImageSession
2020-06-07 03:44:57, Info DISM DISM.EXE: Target image information: OS Version=10.0.18363.836, Image architecture=amd64
2020-06-07 03:44:57, Info DISM DISM.EXE: Image session version: 10.0.18362.1
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Getting the collection of providers from an image provider store type. - CDISMProviderStore::GetProviderCollection
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\CbsProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info CSI 00000001 Shim considered [l:125]'\??\C:\WINDOWS\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.18362.772_none_5f13f94c58ff41d3\wcp.dll' : got STATUS_OBJECT_PATH_NOT_FOUND
2020-06-07 03:44:57, Info CSI 00000002 Shim considered [l:122]'\??\C:\WINDOWS\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.18362.772_none_5f13f94c58ff41d3\wcp.dll' : got STATUS_SUCCESS
2020-06-07 03:44:57, Info DISM DISM Package Manager: PID=9844 TID=6108 Finished initializing the CbsConUI Handler. - CCbsConUIHandler::Initialize
2020-06-07 03:44:57, Info DISM DISM Package Manager: PID=9844 TID=6108 CBS is being initialized for online use. More information about CBS actions can be located at: %windir%\logs\cbs\cbs.log - CDISMPackageManager::Initialize
2020-06-07 03:44:57, Info DISM DISM Package Manager: PID=9844 TID=6108 Loaded servicing stack for online use only. - CDISMPackageManager::CreateCbsSession
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\MsiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\IntlProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\IBSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\DmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM Driver Manager: PID=9844 TID=6108 Further logs for driver related operations can be found in the target operating system at %WINDIR%\inf\setupapi.offline.log - CDriverManager::Initialize
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\UnattendProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\SmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Warning DISM DISM Provider Store: PID=9844 TID=6108 Failed to load the provider: C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\EmbeddedProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\AppxProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\ProvProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\AssocProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\GenericProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\OfflineSetupProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\SysprepProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\TransmogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM Transmog Provider: PID=9844 TID=6108 Current image session is [ONLINE] - CTransmogManager::GetMode
2020-06-07 03:44:57, Info DISM DISM Transmog Provider: PID=9844 TID=6108 Audit Mode: [No] - CTransmogManager::Initialize
2020-06-07 03:44:57, Info DISM DISM Transmog Provider: PID=9844 TID=6108 GetProductType: ProductType = [WinNT] - CTransmogManager::GetProductType
2020-06-07 03:44:57, Info DISM DISM Transmog Provider: PID=9844 TID=6108 Product Type: [WinNT] - CTransmogManager::Initialize
2020-06-07 03:44:57, Info DISM DISM Transmog Provider: PID=9844 TID=6108 Product Type ServerNT : [No] - CTransmogManager::Initialize
2020-06-07 03:44:57, Info DISM DISM Provider Store: PID=9844 TID=6108 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\5AC2C886-278B-463D-86FD-B6A2E17F3860\SetupPlatformProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 03:44:57, Info DISM DISM.EXE: Got the collection of providers. Now enumerating them to build the command table.
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Log Provider
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: OSServices
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Package Manager
2020-06-07 03:44:57, Info DISM DISM.EXE: Succesfully registered commands for the provider: DISM Package Manager.
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: MsiManager
2020-06-07 03:44:57, Info DISM DISM.EXE: Succesfully registered commands for the provider: MsiManager.
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: IntlManager
2020-06-07 03:44:57, Info DISM DISM.EXE: Succesfully registered commands for the provider: IntlManager.
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: IBSManager
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: DriverManager
2020-06-07 03:44:57, Info DISM DISM.EXE: Succesfully registered commands for the provider: DriverManager.
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Unattend Manager
2020-06-07 03:44:57, Info DISM DISM.EXE: Succesfully registered commands for the provider: DISM Unattend Manager.
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: SmiManager
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: AppxManager
2020-06-07 03:44:57, Info DISM DISM.EXE: Succesfully registered commands for the provider: AppxManager.
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: ProvManager
2020-06-07 03:44:57, Info DISM DISM.EXE: Succesfully registered commands for the provider: ProvManager.
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: AssocManager
2020-06-07 03:44:57, Info DISM DISM.EXE: Succesfully registered commands for the provider: AssocManager.
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: GenericManager
2020-06-07 03:44:57, Info DISM DISM.EXE: Succesfully registered commands for the provider: GenericManager.
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: OfflineSetupManager
2020-06-07 03:44:57, Info DISM DISM.EXE: Succesfully registered commands for the provider: OfflineSetupManager.
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: SysprepManager
2020-06-07 03:44:57, Info DISM DISM.EXE: Succesfully registered commands for the provider: SysprepManager.
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: Edition Manager
2020-06-07 03:44:57, Info DISM DISM.EXE: Succesfully registered commands for the provider: Edition Manager.
2020-06-07 03:44:57, Info DISM DISM.EXE: Attempting to add the commands from provider: SetupPlatformManager
2020-06-07 03:44:57, Info DISM DISM.EXE: Succesfully registered commands for the provider: SetupPlatformManager.
2020-06-07 03:44:57, Info DISM DISM Package Manager: PID=9844 TID=6108 Processing the top level command token(cleanup-image). - CPackageManagerCLIHandler:😛rivate_ValidateCmdLine
2020-06-07 03:44:57, Info DISM DISM Package Manager: PID=9844 TID=6108 Attempting to route to appropriate command handler. - CPackageManagerCLIHandler::ExecuteCmdLine
2020-06-07 03:44:57, Info DISM DISM Package Manager: PID=9844 TID=6108 Routing the command... - CPackageManagerCLIHandler::ExecuteCmdLine
2020-06-07 03:44:57, Info DISM DISM Package Manager: PID=9844 TID=6108 CBS session options=0x100! - CDISMPackageManager::Internal_Finalize
2020-06-07 03:46:52, Info CSI 00000001 Shim considered [l:125]'\??\C:\WINDOWS\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.18362.772_none_5f13f94c58ff41d3\wcp.dll' : got STATUS_OBJECT_PATH_NOT_FOUND
2020-06-07 03:46:52, Info CSI 00000002 Shim considered [l:122]'\??\C:\WINDOWS\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.18362.772_none_5f13f94c58ff41d3\wcp.dll' : got STATUS_SUCCESS
2020-06-07 03:46:53, Info DISM DISM Package Manager: PID=9844 TID=6108 DISM has detected a DISM component change. Requesting a shutdown. - CDISMPackageManager::Internal_Finalize
2020-06-07 03:46:53, Info DISM DISM Image Session: PID=9844 TID=6108 The image session needs to be closed and re-opened before any servicing operations can be performed. - CDISMImageSession:😛ut_ImageState
2020-06-07 03:46:53, Info DISM DISM Package Manager: PID=9844 TID=6108 Loaded servicing stack for online use only. - CDISMPackageManager::CreateCbsSession
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Found the PE Provider. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Finalizing the servicing provider(DISM Package Manager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Package Manager: PID=9844 TID=6108 Finalizing CBS core. - CDISMPackageManager::Finalize
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Disconnecting Provider: DISM Package Manager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Finalizing the servicing provider(MsiManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Disconnecting Provider: MsiManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Finalizing the servicing provider(IntlManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Disconnecting Provider: IntlManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Finalizing the servicing provider(IBSManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Disconnecting Provider: IBSManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Finalizing the servicing provider(DriverManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Disconnecting Provider: DriverManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Finalizing the servicing provider(DISM Unattend Manager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Disconnecting Provider: DISM Unattend Manager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Finalizing the servicing provider(SmiManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Disconnecting Provider: SmiManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Finalizing the servicing provider(AppxManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Disconnecting Provider: AppxManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Finalizing the servicing provider(ProvManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Disconnecting Provider: ProvManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Finalizing the servicing provider(AssocManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Disconnecting Provider: AssocManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Finalizing the servicing provider(GenericManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Disconnecting Provider: GenericManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Finalizing the servicing provider(OfflineSetupManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Disconnecting Provider: OfflineSetupManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Finalizing the servicing provider(SysprepManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Disconnecting Provider: SysprepManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Finalizing the servicing provider(Edition Manager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Disconnecting Provider: Edition Manager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Finalizing the servicing provider(SetupPlatformManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Disconnecting Provider: SetupPlatformManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=9844 TID=6108 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Manager: PID=11640 TID=11592 Closing session event handle 0x1f8 - CDISMManager::CleanupImageSessionEntry
2020-06-07 03:46:53, Info DISM DISM.EXE: Image session has been closed. Reboot required=no.
2020-06-07 03:46:53, Info DISM DISM.EXE: <----- Ending Dism.exe session ----->
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=11640 TID=11592 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=11640 TID=11592 Disconnecting Provider: FolderManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 03:46:53, Info DISM DISM Provider Store: PID=11640 TID=11592 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM PID=10476 TID=7380 Scratch directory set to 'C:\Users\krist\AppData\Local\Temp\'. - CDISMManager:😛ut_ScratchDir
2020-06-07 14:48:01, Info DISM PID=10476 TID=7380 DismCore.dll version: 10.0.18362.1 - CDISMManager::FinalConstruct
2020-06-07 14:48:01, Info DISM Initialized Panther logging at C:\WINDOWS\Logs\DISM\dism.log
2020-06-07 14:48:01, Info DISM PID=10476 TID=7380 Successfully loaded the ImageSession at "C:\WINDOWS\system32\Dism" - CDISMManager::LoadLocalImageSession
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=10476 TID=7380 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=10476 TID=7380 Failed to get and initialize the PE Provider. Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=10476 TID=7380 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2020-06-07 14:48:01, Info DISM DISM Manager: PID=10476 TID=7380 Successfully created the local image session and provider store. - CDISMManager::CreateLocalImageSession
2020-06-07 14:48:01, Info DISM DISM.EXE:
2020-06-07 14:48:01, Info DISM DISM.EXE: <----- Starting Dism.exe session ----->
2020-06-07 14:48:01, Info DISM DISM.EXE: Host machine information: OS Version=10.0.18363, Running architecture=amd64, Number of processors=6
2020-06-07 14:48:01, Info DISM DISM.EXE: Dism.exe version: 10.0.18362.1
2020-06-07 14:48:01, Info DISM DISM.EXE: Executing command line: dism /repair /online /windowsimage /restorehealth
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=10476 TID=7380 Connecting to the provider located at C:\WINDOWS\system32\Dism\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM Manager: PID=10476 TID=7380 physical location path: C:\ - CDISMManager::CreateImageSession
2020-06-07 14:48:01, Info DISM DISM Manager: PID=10476 TID=7380 Event name for current DISM session is Global\{A2C8C12D-DB25-4ACA-BB90-9C90AF4F4641} - CDISMManager::CheckSessionAndLock
2020-06-07 14:48:01, Info DISM DISM Manager: PID=10476 TID=7380 Create session event 0x1f8 for current DISM session and event name is Global\{A2C8C12D-DB25-4ACA-BB90-9C90AF4F4641} - CDISMManager::CheckSessionAndLock
2020-06-07 14:48:01, Info DISM DISM Manager: PID=10476 TID=7380 Copying DISM from "C:\WINDOWS\System32\Dism" - CDISMManager::CreateImageSessionFromLocation
2020-06-07 14:48:01, Info DISM DISM Manager: PID=10476 TID=7380 Successfully loaded the ImageSession at "C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2" - CDISMManager::LoadRemoteImageSession
2020-06-07 14:48:01, Info DISM DISM Image Session: PID=2888 TID=9596 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM OS Provider: PID=2888 TID=9596 Defaulting SystemPath to C:\ - CDISMOSServiceManager::Final_OnConnect
2020-06-07 14:48:01, Info DISM DISM OS Provider: PID=2888 TID=9596 Defaulting Windows folder to C:\Windows - CDISMOSServiceManager::Final_OnConnect
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2020-06-07 14:48:01, Warning DISM DISM Provider Store: PID=2888 TID=9596 Failed to load the provider: C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\PEProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Failed to get and initialize the PE Provider. Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2020-06-07 14:48:01, Info DISM DISM Manager: PID=10476 TID=7380 Image session successfully loaded from the temporary location: C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2 - CDISMManager::CreateImageSession
2020-06-07 14:48:01, Info DISM DISM.EXE: Target image information: OS Version=10.0.18363.836, Image architecture=amd64
2020-06-07 14:48:01, Info DISM DISM.EXE: Image session version: 10.0.18362.1
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Getting the collection of providers from an image provider store type. - CDISMProviderStore::GetProviderCollection
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\CbsProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info CSI 00000001 Shim considered [l:125]'\??\C:\WINDOWS\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.18362.772_none_5f13f94c58ff41d3\wcp.dll' : got STATUS_OBJECT_PATH_NOT_FOUND
2020-06-07 14:48:01, Info CSI 00000002 Shim considered [l:122]'\??\C:\WINDOWS\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.18362.772_none_5f13f94c58ff41d3\wcp.dll' : got STATUS_SUCCESS
2020-06-07 14:48:01, Info DISM DISM Package Manager: PID=2888 TID=9596 Finished initializing the CbsConUI Handler. - CCbsConUIHandler::Initialize
2020-06-07 14:48:01, Info DISM DISM Package Manager: PID=2888 TID=9596 CBS is being initialized for online use. More information about CBS actions can be located at: %windir%\logs\cbs\cbs.log - CDISMPackageManager::Initialize
2020-06-07 14:48:01, Info DISM DISM Package Manager: PID=2888 TID=9596 Loaded servicing stack for online use only. - CDISMPackageManager::CreateCbsSession
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\MsiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\IntlProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\IBSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\DmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM Driver Manager: PID=2888 TID=9596 Further logs for driver related operations can be found in the target operating system at %WINDIR%\inf\setupapi.offline.log - CDriverManager::Initialize
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\UnattendProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\SmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Warning DISM DISM Provider Store: PID=2888 TID=9596 Failed to load the provider: C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\EmbeddedProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\AppxProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\ProvProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\AssocProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\GenericProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\OfflineSetupProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\SysprepProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\TransmogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM Transmog Provider: PID=2888 TID=9596 Current image session is [ONLINE] - CTransmogManager::GetMode
2020-06-07 14:48:01, Info DISM DISM Transmog Provider: PID=2888 TID=9596 Audit Mode: [No] - CTransmogManager::Initialize
2020-06-07 14:48:01, Info DISM DISM Transmog Provider: PID=2888 TID=9596 GetProductType: ProductType = [WinNT] - CTransmogManager::GetProductType
2020-06-07 14:48:01, Info DISM DISM Transmog Provider: PID=2888 TID=9596 Product Type: [WinNT] - CTransmogManager::Initialize
2020-06-07 14:48:01, Info DISM DISM Transmog Provider: PID=2888 TID=9596 Product Type ServerNT : [No] - CTransmogManager::Initialize
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Connecting to the provider located at C:\Users\krist\AppData\Local\Temp\91908626-8C1F-41ED-BBBF-8697C62750A2\SetupPlatformProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-06-07 14:48:01, Info DISM DISM.EXE: Got the collection of providers. Now enumerating them to build the command table.
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Log Provider
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: OSServices
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Package Manager
2020-06-07 14:48:01, Info DISM DISM.EXE: Succesfully registered commands for the provider: DISM Package Manager.
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: MsiManager
2020-06-07 14:48:01, Info DISM DISM.EXE: Succesfully registered commands for the provider: MsiManager.
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: IntlManager
2020-06-07 14:48:01, Info DISM DISM.EXE: Succesfully registered commands for the provider: IntlManager.
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: IBSManager
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: DriverManager
2020-06-07 14:48:01, Info DISM DISM.EXE: Succesfully registered commands for the provider: DriverManager.
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Unattend Manager
2020-06-07 14:48:01, Info DISM DISM.EXE: Succesfully registered commands for the provider: DISM Unattend Manager.
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: SmiManager
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: AppxManager
2020-06-07 14:48:01, Info DISM DISM.EXE: Succesfully registered commands for the provider: AppxManager.
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: ProvManager
2020-06-07 14:48:01, Info DISM DISM.EXE: Succesfully registered commands for the provider: ProvManager.
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: AssocManager
2020-06-07 14:48:01, Info DISM DISM.EXE: Succesfully registered commands for the provider: AssocManager.
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: GenericManager
2020-06-07 14:48:01, Info DISM DISM.EXE: Succesfully registered commands for the provider: GenericManager.
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: OfflineSetupManager
2020-06-07 14:48:01, Info DISM DISM.EXE: Succesfully registered commands for the provider: OfflineSetupManager.
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: SysprepManager
2020-06-07 14:48:01, Info DISM DISM.EXE: Succesfully registered commands for the provider: SysprepManager.
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: Edition Manager
2020-06-07 14:48:01, Info DISM DISM.EXE: Succesfully registered commands for the provider: Edition Manager.
2020-06-07 14:48:01, Info DISM DISM.EXE: Attempting to add the commands from provider: SetupPlatformManager
2020-06-07 14:48:01, Info DISM DISM.EXE: Succesfully registered commands for the provider: SetupPlatformManager.
2020-06-07 14:48:01, Error DISM DISM.EXE: No providers were found that support the command(repair). HRESULT=80070057
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Found the PE Provider. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Finalizing the servicing provider(DISM Package Manager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Package Manager: PID=2888 TID=9596 Finalizing CBS core. - CDISMPackageManager::Finalize
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Disconnecting Provider: DISM Package Manager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Finalizing the servicing provider(MsiManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Disconnecting Provider: MsiManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Finalizing the servicing provider(IntlManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Disconnecting Provider: IntlManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Finalizing the servicing provider(IBSManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Disconnecting Provider: IBSManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Finalizing the servicing provider(DriverManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Disconnecting Provider: DriverManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Finalizing the servicing provider(DISM Unattend Manager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Disconnecting Provider: DISM Unattend Manager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Finalizing the servicing provider(SmiManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Disconnecting Provider: SmiManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Finalizing the servicing provider(AppxManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Disconnecting Provider: AppxManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Finalizing the servicing provider(ProvManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Disconnecting Provider: ProvManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Finalizing the servicing provider(AssocManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Disconnecting Provider: AssocManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Finalizing the servicing provider(GenericManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Disconnecting Provider: GenericManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Finalizing the servicing provider(OfflineSetupManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Disconnecting Provider: OfflineSetupManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Finalizing the servicing provider(SysprepManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Disconnecting Provider: SysprepManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Finalizing the servicing provider(Edition Manager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Disconnecting Provider: Edition Manager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Finalizing the servicing provider(SetupPlatformManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Disconnecting Provider: SetupPlatformManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=2888 TID=9596 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Manager: PID=10476 TID=7380 Closing session event handle 0x1f8 - CDISMManager::CleanupImageSessionEntry
2020-06-07 14:48:01, Info DISM DISM.EXE: Image session has been closed. Reboot required=no.
2020-06-07 14:48:01, Info DISM DISM.EXE: <----- Ending Dism.exe session ----->
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=10476 TID=7380 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=10476 TID=7380 Disconnecting Provider: FolderManager - CDISMProviderStore::Internal_DisconnectProvider
2020-06-07 14:48:01, Info DISM DISM Provider Store: PID=10476 TID=7380 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
My setup:
I5 8600
Gtx 1050 ti
Had 1 stick of generic green 8gb 2133 ram that I switched for 2x8 2133 vengeance lpx both ddr4
Prime h310m-a asus mobo
thanks for taking the time to help me, appreciate it.
I tested them borh had 500 errors and now I tested one at a time got 0 errors, im rly confused
Could be the slot you didn't use the second time around (when you only used 1 stick) is the problem?
I did the scan on both rams and in different sockets. I turned my pc on and now sound works and everything is fine for the moment. Thanks mate
Were the sticks in the right slots to start with?
Glad you worked it out
