Ryzen 3700X
GTX 2070 Super
Gigabyte x570 Aorus Elite
NZXT H510
EVGA 750 GQ 80PLUS GOLD
Samsung DDR4 32G (16x2) (2666MHz)
EVO 860 1TB (from my previous system)
Okay, so that is my build for a gaming, streaming, graphic design and video editing (illustrator, after effects, premiere).
Dilemma 1: RAM
I read that Ryzen makes good use of fast memory. But they are expensive. Where I live, 32GB of 3200MHz costs $200, while the 2666MHz costs $100.
Do you think this worth it? Or is it better spend somewhere else?
Dilemma 2: Aftermarket CPU cooler
I am not going to overclock. But I am going to stream, render, edit everyday the whole day. I heard the stock cooler runs pretty loud under load. I was thinking an aftermarket cooler would keep it quite and increase the longevity of the CPU by running it a few degrees cooler. I like the NZXT case, so I feel like pairing it up with the Kraken x62. But it also feels like a lot of money for a 3700X (that won't even be OCed). I'm not opposed to air cooling, but those Dark Rock Pro 4 seem to take up the whole space which really takes away the point of these cases that display the inside (unless you like the look of the DRP4). I also feel like dusting the system out every once in a while should be easier with the AIO. However, I'm still willing to be persuaded to air coolers, or even the stock cooler, if Kraken x62 is too much of an overkill for this build and my use. After all, going stock over the AIO will save me almost enough money to upgrade to the 3900X.
Dilemma 3: Mainboard
Since I'm getting a case to show off the inside, I went with the X570 over the B450. Plus the better VRMs and more USB ports. But again it is the cost. X570 is around $230, B450 is around $100. And I don't need the PCIe 4.0 nor the SLI feature. And I don't even know what the fans on the X570 do.
Dilemma 4: PSU
Should I go with 650W? Is the 750 too much?
Dilemma 5: GPU
Rumor has it that the Nvidia Ampere (3000 series) will be coming in the first half (or even the first quarter) of 2020. I was thinking of using my 1060 for a while and buy the GPU later on when the 3000 series comes out. Do you think it is a good plan?
That's pretty much it.
I guess it comes down to, do I want a nice computer to look at, or a fast computer. But I'd really like to hear your opinions because I am so undecided right now.
GTX 2070 Super
NZXT H510
Dilemma 1: RAM
Dilemma 4: PSU
Dilemma 5: GPU
