Just boought a MSI GeForce GTX 1660 ARMOR OC 6GB and the fan noise is loud even at 30-35 degrees. I'm assuming the fans are running at full speed for some reason?
In the first instance what is the best way to control the fan speed of the GPU, so I can see if that is the issue? Should I assume its faulty?
Thanks
Thanks
