Question Loud psu fan while under load
May 23, 2020
Hello guys after 9 months of using my psu thermaltake smart rgb 500w this week i noticed its making loud fan noise ( like the fan is speeding up a lot ) when under load ( GPU 97% temp : 65c-73c) and also another noice shows from time to time its like the fan is touching something is it the temp ? what can i do ? and should i rma it or replace it ??
My pc :
Ryzen 5 2600X 3.6Ghz
8GB RAM DDR4 2666mhz
Asus b450m_k prime
MSI GTX 1660 Gaming X
May 23, 2020
The "SMART" is Thermaltake's cheapest PSU.
Poor efficiency (meaning it generates a lot of its own heat) and sleeve bearing fan (meaning it doesn't last long).
What country are you in?
im from algeria dude
should i replace it ?
what do you think about cooler master mwe 650W white ?
jonnyguru
Hmm.. I'm not familiar with consumer protection laws in Algeria.
In the EU, you have the right to return the product to wherever you bought it from for 2 years after initial purchase and get something different.
I, personally, would try to return it and get something different.
