Low budget gaming PC build for CSGO and PUBG.
jainamss
17
Hi guys,
I am wanting to build my 1st gaming pc to play mostly CSGO and sometimes PUBG. This PC should get constant 200+ fps on CSGO (i normally low settings and 1024*768 resolution, but also should get decent fps if i increase settings.) Also, the PC should be able to get 60 fps on PUBG on medium or high settings. My budget is $600-$700.
Dont have any cpu prefrences but would like a HDD because I need storage for games.
Thanks a lot guys :)
A bit over, but has a 1060 6GB which would ensure really good gaming for 1080p as well, and will handle 200+ FPS for CSGO. Bit expensive as it has an SSD for your OS and an HDD for your games.
PCPartPicker part list: https://pcpartpicker.com/list/9ZgJCy
Price breakdown by merchant: https://pcpartpicker.com/list/9ZgJCy/by_merchant/
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor ($109.99 @ Amazon)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard ($56.98 @ Newegg)
Memory: Crucial - 8GB (2 x 4GB) DDR4-2400 Memory ($87.99 @ SuperBiiz)
Storage: Kingston - A400 120GB 2.5" Solid State Drive ($49.99 @ Best Buy)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($46.68 @ OutletPC)
Video Card: EVGA -...
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card ($289.79 @ SuperBiiz)
Case: Corsair - 200R ATX Mid Tower Case ($34.99 @ Newegg)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($52.98 @ Newegg)
Total: $729.39
Generated by PCPartPicker 2018-01-08 21:13 EST-0500
Hi,
Thanks for the reply. I was wondering if I could substitute the GPU for one that is a bit cheaper, I am currently not looking for an SSD so will remove that and will upgrade later. Otherwise great build. Thanks a lot :)
Sure, a 1050Ti is not a bad option. A bit less performance, however. By dropping SSD, you save more money too.
Yep thanks a lot,
Could you take a look at this and tell me if it looks good and if I can add anything more. I am willing to spend about 70$ more on this build (not looking for a SSD atm). https://pcpartpicker.com/list/WQRTbj
It looks good, but try to get Dual Channel RAM (2 x 4GB) at 3000 MHz as Ryzen loves 3000 MHz RAM.
Hi,
Any suggestions for 2 x 4GB ram at similar price?
2 x 4 GB and 3000MHz
PCPartPicker part list: https://pcpartpicker.com/list/GvWXQ7
Price breakdown by merchant: https://pcpartpicker.com/list/GvWXQ7/by_merchant/
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory ($113.99 @ Amazon)
Total: $113.99
Generated by PCPartPicker 2018-01-08 23:35 EST-0500
2 x 4 GB but not 3000 MHz
PCPartPicker part list: https://pcpartpicker.com/list/wh6hVY
Price breakdown by merchant: https://pcpartpicker.com/list/wh6hVY/by_merchant/
Total: $87.99
Generated by PCPartPicker 2018-01-08 23:37 EST-0500
Thanks a lot, this has been great 😀
